EEVEE lighsource reflections bug or feature? (shadows being used for visibility could be documented) #89556
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#89556
Graphics card: Quadro K4000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 462.59
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-06-24 17:40, hash:
blender/blender@3d7021b4ec
Worked: (doesnt work even in 2.83 LTS)
From the attached images and file there seems to be an issue where reflections dont show up when a light is present, while using an emission surface gives the expected result. Please note that using reflection planes, cube mapps do nothing to the scene, it seems that EEVEE overlays lights reflections on top of everything, except surface roughness. I`m not sure if its a bug or a feature.
Please see attached file
White room bug.blend
Added subscriber: @Pastean_Narcis_Dan
Added subscriber: @ktdfly
AFAIK that's a limitation of LTC shading - specular highlights are only checked if in direct shadow, reflected rays are not checked
Added subscribers: @fclem, @lichtwerk
Yep, I think this comes down to a limitation, but will let @fclem have the final word.
In Eevee, specular reflections of the light itself are "blocked" by the shadow maps (same as diffuse), these are not shadow rays.
This is a very simplistic example:
repro.blend
Cycles:
Eevee:
note this is all pure specular.
So yeah, one could says these are "wrong" in Eevee, but this is probably just the best you can get for area light sources in a realtime scenario (or is raytracing here a things as well nowadays)?
@fclem: dont see this mentioned in the documentation, maybe it should?
EEVEE reflections bug or feature?to EEVEE lighsource reflections bug or feature? (shadowmap blocking)Shadowing (or visibility) is not generally separable from shading but for realtime rendering purpose we consider this to be true as we only have shadowing information for one direction.
I guess this could be added as limitation of the shadow system in the documentation.
Raytracing the shadow map is not going to fix it because we will still only stick to the separability assumption to avoid twice the cost of shadows (which will be very high for raytracing).
thx sharing the info @fclem
Will set to TODO then.
EEVEE lighsource reflections bug or feature? (shadowmap blocking)to EEVEE lighsource reflections bug or feature? (shadows being used for visibility could be documented)
