Object information is lost when applying geometry nodes #89632
Reference: blender/blender#89632
Graphics card: AMD Radeon RX 5700 XT ATI Technologies Inc. 4.5.14830 Core Profile Context 21.4.1 27.20.21002.112
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-07-02 18:27, hash:
5f5cf21a83
Worked: Unknown
Applying geometry nodes loses a lot of relevant shader information, which can cause the object to be completely unusable after the application.
To repro from file:
Effect in example file:
Example material:
Example file:
geo-apply.blend
Could maybe a special Apply function be added, that causes the instances to be created as actual separate objects?
(That would not solve the situation with additional modifiers after the Geometry Nodes though...)
Added subscriber: @brunnerh
Thanks for the report. I think this is similar to: #85962 (Many Nodes (Join geometry, Boolean, Object Info?) and realizing instances remove UVs (output float2, not MLoopUV).)
@PratikPB2123 Yes, this is similar in that data is lost, but this is not about the UVs.
Aside from object IDs, curves also are lost, presumably because the resulting singular object cannot be a mesh and curve at the same time.
If you look at my book shelf example, you can see curve based ornaments at the bottom, they can be joined using Join Geometry but upon application they disappear.
When you combine multiple objects into one, then the Object Info node in cycles will output the same random value for every vertex in that object. That is expected. However, I can see that it can be a bit confusing sometimes when you are not aware that your shader depends on there being separate objects.
There are some limitations when it comes to applying instances, but I don't consider this to be a bug currently.
You can use the
F3 -> Make Instances Real
operator for that.Make Instances Real
is good to know about, though it also has the limitation that the result will not be equivalent.The names of the generated instances will affect the randomness in the shader, so all those instances will look different than those in the source object.
