image datablocks report 1 user if they've ever been opened in the image editor but have no actual users. #89644
Reference: blender/blender#89644
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.92
Broken: version: 2.93.2 Release Candidate, branch: master, commit date: 2021-06-23 12:44, hash:
03d5c8b4ed
check in the blend data and you'll see it still has one user.
This is problematic, because it means you cant delete image datablocks via python if they have no users, because they always report as having one if they ever appeared in the image editor.
Added subscriber: @3di
Added subscriber: @mano-wii
I'm not sure if the Compositor step is really needed to reproduce the described behavior.
If you load the image into the image editor and press the x, the users are not reset either.
This is the same behavior in older versions of Blender.
It's as if every added image already comes with 1 user by default.
You need to press Shift + X to make the amount of users 0.
Did I misunderstand the problem?
Hi Germano, yes I think you may have misunderstood. You're only getting one user by default because you're creating the image from the image editor. If you create it elsewhere then the image editor won't count towards it's users (it'll still be one user (the actual user/node) until you open it in an image editor, then it'll be two users).
Basically I have some python code which needs to remove the image datablock if it's not in actual use by a part of blender which is using it for calculations. I don't think the UI should be classed as a user because there doesn't appear to be a way to differentiate between an actual user and a UI user, so you have to manually loop through and check everything in the blend file which could potentially be using that datablock, which isn't very performant.
Perhaps datablock.users could return a list of users rather than just an integer. Then the programmer could check they type of users and ignore those that are of type UI (if that is a type)
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Maybe the fact of viewing the image in the image editor adds
1
user is intentional?The operator in
X
might intentionally avoid making the user quantity0
.I have to study the code to be sure, but I still don't think it's a bug.
Added subscriber: @mont29
there is indeed no bug here, currently Blender relies on non-null user count to keep data-blocks around. 'shallow' users like image editors use a mechanism (check how
LIB_TAG_EXTRAUSER
/LIB_TAG_EXTRAUSER_SET
are used in the code) that ensures that there is at least one user set when an image is assigned to an image editor e.g..We have plans to change a bit how IDs are handled (and freed) by Blender in the future, see #61209 (Always write unused IDs on save). But currently this behavior is expected and definitely not a bug.
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
@mont29 should it not remove the user when pressing X in the image editor? And so that I can ignore the user if it's part of the UI, is there a way to differentiate in python between an actual user, and a UI user.....if not, is it possible to remove the user from the image editor and other UI elements via python? something like:
for img in bpy.data.images:
Cheers 👍
