Addon isn't downloading even when it says "Module Succesfully downloaded" #89651
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#89651
Well, to say I'm not a expert in blender..
Well from what I know I can state this Concern as an Bug
Reason: Whenever I download an Addon It states it has been succesfully downloaded
If this isn't an Bug.. well Atleast I think It is since an option isnt working completely
well You might say The addon isnt working or it isnt compatable but it is compatable
since it worked before my blender crashed and when I restarted it.. the addon dosen't work
I need your help on fixing this bug since the Addon is one of my main UI's..
Added subscriber: @surajthegamers
@surajthegamers , thanks for the report. can you please mention the culprit add-on.
Sounds like you are trying to install 3rd party add-on.
Present report does not contain all the requested information, which is required for us to investigate the issue.
Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
Added subscriber: @rjg
Please make sure to install the add-on through the preferences (Edit > Preferences > Add-ons > Install). A common mistake for projects hosted on GitHub is to just download the repository as ZIP. However, some repositories aren't structured to have the
__init__.py
in the top most directory, thus attempting to install it will result in a non-functional add-on. Those repositories will most likely offer a properly packaged add-on in the release section of the repository.For more detailed instructions see this answer on Blender's Stack Exchange.
