Some particle hairs that emitted from the vertices do not rotate with the armature.
Confirmed, NormalPublic
Operating system:MacOS
Graphics card:Radeon Pro
Broken: 2.93.2
Simple example wit a cube:
Issue only happens when emitting from Vertices (emitting from faces is fine)
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Fri, Jul 9, 7:34 AM
Could you share an example .blend file demonstrating the issue?
This is the file.
pls check this.
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Needs Triage.Fri, Jul 9, 12:40 PM
Philipp Oeser (lichtwerk) updated the task description. (Show Details)
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Fri, Jul 9, 1:05 PM
Richard Antalik (ISS) changed the task status from Confirmed to Needs Information from User.Fri, Jul 9, 1:09 PM
I am able to reproduce this issue, @Kihaku Gisui (Kihaku_Gisui) can you also upload very simple cube file? I wasn't able ro create such file from scratch. If you can also share steps to create such file it would be nice.
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Confirmed.Fri, Jul 9, 1:24 PM
Thank you @Richard van der Veen (richard) Antalik (ISS)
This is it!
Please check it out.
