Optix not working (CPU and GPU) in Viewport #89764
Closed
opened 2021-07-09 20:32:42 +02:00 by Characterhero · 10 comments
Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 462.31
Broken: version: 2.93.2 Release Candidate, branch: master, commit date: 2021-07-07 05:52, hash: 9e64fd461a and 3.0.0 Alpha, branch: master, commit date: 2021-07-08 17:54, hash: af8fb707da
Worked: Blender 2.92
Blender cannot build kernel when denoise is enabled. Also freezes when switching modes.
Blender 2.92
Blender 2.93.2
Blender 3.0
test.blend
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 462.31 **Blender Version** Broken: version: 2.93.2 Release Candidate, branch: master, commit date: 2021-07-07 05:52, hash: `9e64fd461a` and 3.0.0 Alpha, branch: master, commit date: 2021-07-08 17:54, hash: `af8fb707da` Worked: Blender 2.92 **Short description of error** Blender cannot build kernel when denoise is enabled. Also freezes when switching modes. Blender 2.92 ![cycles_gpu_292_optix.JPG](https://archive.blender.org/developer/F10218498/cycles_gpu_292_optix.JPG) ![cycles_gpu_292_oid.JPG](https://archive.blender.org/developer/F10218499/cycles_gpu_292_oid.JPG) ![2.92_cpu.JPG](https://archive.blender.org/developer/F10218577/2.92_cpu.JPG) Blender 2.93.2 ![cycles_gpu_293_noise.JPG](https://archive.blender.org/developer/F10218503/cycles_gpu_293_noise.JPG) ![cycles_gpu_293_optix.JPG](https://archive.blender.org/developer/F10218502/cycles_gpu_293_optix.JPG) ![cpu_2.93.JPG](https://archive.blender.org/developer/F10218584/cpu_2.93.JPG) Blender 3.0 ![3.0_gpu.JPG](https://archive.blender.org/developer/F10218530/3.0_gpu.JPG) ![3.0_gpu.JPG](https://archive.blender.org/developer/F10218512/3.0_gpu.JPG) ![3.0_cpu.JPG](https://archive.blender.org/developer/F10218592/3.0_cpu.JPG) [test.blend](https://archive.blender.org/developer/F10218534/test.blend)
Author
Added subscriber: @TheCharacterhero-4
Member
Added subscriber: @Alaska
Member
Member
It says in the top left of Blender "Loading Render Kernels (may take a few minutes the first time)", have you tried waiting a while for the kernels to load?
Another thing to take a look at is your GPU drivers. At the moment you're running drivers that are quite old, updating them, rebooting your computer, then opening Blender and waiting the few minutes for the render kernels to load might help: https://www.nvidia.com/Download/index.aspx
If neither of these help, maybe loading factory settings can help? Select from the top of Blender File -> Defaults -> Load Factory Settings then open preferences and re-enable your GPU then test OptiX denoising again and see if it helps. If it does, that means one of the settings you've changed or an add-on you've installed or something is causing issues.
I'm not sure what else to suggest.
It also seems like this report might be very similar to the one reported here: #89389 (Optix kernels not loading), can you confirm this?
It says in the top left of Blender "Loading Render Kernels (may take a few minutes the first time)", have you tried waiting a while for the kernels to load? Another thing to take a look at is your GPU drivers. At the moment you're running drivers that are quite old, updating them, rebooting your computer, then opening Blender and waiting the few minutes for the render kernels to load might help: https://www.nvidia.com/Download/index.aspx If neither of these help, maybe loading factory settings can help? Select from the top of Blender `File -> Defaults -> Load Factory Settings` then open preferences and re-enable your GPU then test OptiX denoising again and see if it helps. If it does, that means one of the settings you've changed or an add-on you've installed or something is causing issues. I'm not sure what else to suggest. It also seems like this report might be very similar to the one reported here: #89389 (Optix kernels not loading), can you confirm this?
Member
Author
I downloaded the latest drivers, the problem is not resolved.
#89389: Optix kernels not loading
Yes that's it.
I downloaded the latest drivers, the problem is not resolved. [#89389: Optix kernels not loading ](https://developer.blender.org/T89389) Yes that's it.
Member
Closing the report as a duplicate of {#89389}
edit: Before that please confirm if the issue is same when you render the scene with denoising (viewport/render) option disabled?
~~Closing the report as a duplicate of {#89389}~~ edit: Before that please confirm if the issue is same when you render the scene with denoising (viewport/render) option disabled?
Author
This problem occurs when turning on Optix
> In #89764#1191366, @PratikPB2123 wrote: > ~~Closing the report as a duplicate of {#89389}~~ > > edit: Before that please confirm if the issue is same when you render the scene with denoising (viewport/render) option disabled? This problem occurs when turning on Optix
Member
Thanks for checking. I will merge this report with #89389
>This problem occurs when turning on Optix Thanks for checking. I will merge this report with #89389
Member
Closed as duplicate of #89389
Reference: blender/blender#89764
