Geometry Nodes crash when using Material Assign node on instanced Bezier object during render. #89781
Reference: blender/blender#89781
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.11
Broken: version: 3.0.0 Alpha, branch: cycles-x, commit date: 2021-07-06 15:38, hash:
3ea9646c18
Worked: NA
Geometry Nodes crash when using Material Assign node on instanced Bezier geometry during render. Additionally using Material Assign node makes instanced Bezier object no longer appear in the viewport.
The following error when running in debug mode and right after switching view to Rendered mode.
Open attached file and change view to Rendered, Blender will crash. Also, mute Material Assign node and note that geometry is now visible in the viewport.
GN_crash.blend
Added subscriber: @valera-8
Cannot recreate on 3.0.0 (
62d9dabc7d
). Please confirm if crash happens on master branch build also.Changing viewport shading to render does not cause the blender to crash.
If issue is specific for cycles-X branch then I will have to close the task
Reason: the tracker is yet not open for Cycles-X bug reports. Branch is under development so sometimes unknown issue may occur.
If crash happen for master branch build then please attach crash logs (refer: https://docs.blender.org/manual/en/3.0/troubleshooting/crash.html#windows)
Crashes in latest version: 3.0.0 Alpha, branch: master, commit date: 2021-07-10 13:52, hash:
49a363f0e0
as well.GN_crash.crash.txt
Edit: looks like you have a more up to date version of Blender. Can you share a download link? Mine is from the blender.org experimental page.
Can recreate the crash with Cycles render engine. (No crash here with EEVEE)
Experimental builds are enough, I use the same and also I pull the changes from the master branch to use blender with most recent updates.
[NO similar report I found on tracker so confirming]
This seems to be partially solved by the combination of D11841 and D11597, but not entirely yet..
I can't reproduce the issue anymore, can you?
Can not reproduce either on master and
blender-v3.0-release
branch build (11392829ad
)I assume this is fixed (if needed I would also find the commit that fixes this issue).
(I assume this is fixed and can be closed)
