Circle Select tool: status bar info doesn't match with the actual operations #89909
Reference: blender/blender#89909
Graphics card: Intel(R) UHD Graphics 620 Intel 4.5.0 - Build 25.20.100.6444
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-06-23 22:10, hash:
f7fbb518c8
Worked: NA
The "Select circle" command is riddled with problems:
Issue 1
When we choose the "Circle Select" tool, the status line does not provide the relevant information at all.
Once we press the LMB down, the status line changes to-
Issue 2
Even this is totally faulty:
I found experimentally that when we roll the mouse wheel while the LMB is pressed down, the diameter changes.
Issue 3
At this time, the mouse shows two different circles simultaneously: The new circle is in dotted line. The default circle is in solid line. Showing two circles at a time is totally unnecessary, and does not serve any purpose.
Even in the light of this decoded behavior, I cannot guess what "MsPan" means!
See above
Suggested solutions:
Added subscriber: @raindrops
#98084 was marked as duplicate of this issue
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Similar report is present on tracker: #83394 (Tool shelf circle select. Changing the brush radius by hotkey does not update the radius)
(I will remove it from description)
Please check again with factory settings (
File -> defaults -> Load Factory settings
). Can deselect here in both ways (MMB
Shift + LMB
).Choosing
select circle
option from toolbar and pressing the LMB shows the different info. This looks inconsistent.Agree with some changes mentioned in the report. #user_interface developers will take the final decision.
Adding multiple issues in single report is not really good but all the changes looks useful and almost same so it's better to keep them together.
The Circle Select tool is not intuitive; and the status line hints do not match its behaviorto Circle Select tool: insufficient information on status bar.I reverted to factory settings. I can deselect objects with CTRL+LMB, but not with SHFT+LMB or SHFT+MMB or MMB.
Another problem is that usually such hotkeys toggle the selection status of an individual object.
(This is a convenient way to add/remove an objection to the selection.)
But CTRL+LMB only deselects: It cannot select the object! This also can be considered a bug.
I confirmed this by repeating the entire cycle twice.
BTW the problem is not only about wrong information in the status line: It is also about multiple affordances that are wrong.
It is also about not using a well-set convention that exists in Blender itself.
For example, why don't we press the F key and then drag the mouse to set the size of the circle (as in sculpt brush)?
Added subscriber: @blendask
Circle Select tool: insufficient information on status bar.to Circle Select tool: status bas info doesn't match with the actual operationsCircle Select tool: status bas info doesn't match with the actual operationsto Circle Select tool: status bar info doesn't match with the actual operationsThis issue was referenced by
113b8030ce
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
