VSE: Select more/less functionality breaks on certain conditions #89913
Reference: blender/blender#89913
Operating system: Linux Mint 20
Graphics card: NVIDIA G92 [GeForce 9800 GT]
Broken: 2.93.1 / 2.92.0
Worked: Unsure
The functions sequencer.select_more and sequencer.select_less get stuck when the newly selected strip reaches an edge, or when number of selected strips becomes zero.
blender-bug__select-more-less.mp4
The attached video shows the functions [select_more]/[select_less] will break when the following conditions are met:
I think it's unlikely this is intended behaviour?
Sorry I didn't get visual keypresses set up for the video, but I'm just using CTL- [x] and CTL- [x] on num pad as per default.
David
Added subscriber: @slinkeepie
At least a strip needs to be selected to expand or reduce the selected elements. So I don't think this is a bug or so.
Don't think this is expected. Also: Selection works same in edit mode when all edge/face/verts are selected.
You're right, probably not technically a bug... but with regards to these functions, it seems counterintuitive.
Glad you agree with that :)
As for behaviour on edge reach by dual-expanded selection, that has a bit of room for interpretation on what the most logical behaviour is... probably whatever side gets increased past the edge (one activation past reaching the edge) should stay stuck, turning it into a singly expanded selection at that point. But it's a fairly niche usage of the function to be honest. It would be more helpful to have a [select_more_to_left] and [select_more_to_right] function split...
Thanks so much for the quick response!
David
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Added subscriber: @iss
@iss can you please check the issue?
Select less
presently does not work when all strips are selected. Is this a known issue or an intentional behavior?Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
In VSE select less fails, because strip doesn't have any unselected neighbors, which looks like bug. It really should shrink selection from edges.
Issue, that select less can end up with no selection is intended behavior. Not sure if it's useful in VSE. If this is issue for your workflow, please explain bit more in detail.
The behavior seems to be the same in 3D edit mode with vertices. Perhaps it's same issue.
Thanks Richard...
There's no problem with ending up with zero selection (seems expected). As for starting up from zero selection at the point last selected, it would require something context sensitive that probably isn't worth the work for a niche case of a fairly niche operation I guess. It's just something I noticed that seemed not quite right to my very stringent brain when customizing my hotkeys and testing what all the functions do hehe. Not sure if it would be useful in other modes since I mainly edit...
Agreed that full selection should definitely shrink down when select_less is used.
David
