doesn't work when I login for another user in windows 10 #89914
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#89914
Graphics card: NVIDIA GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.11
Broken: version: 2.93.1, branch: master, commit date: 2021-06-22 05:57, hash:
blender/blender@1b8d33b18c
Addon Information
Name: Bool Tool (0, 4, 1)
Author: Vitor Balbio, Mikhail Rachinskiy, TynkaTopi, Meta-Androcto, Simon Appelt
I login in windows 10 for another user (not mainly user in system). This user have admin permisions. And new objects of this tool is not displayed in context menu for adding objects
Added subscriber: @TaoGen
Added subscriber: @Alaska
Whether or not an add-on is enabled is saved to a file that is different for every user on the computer. As such if you enable
Bool Tool
on one user, save your preferences, then change to another user, it will not be enabled.Can you please check and confirm that Bool Tool is enabled for the other user? If it's not, then enable it and see if it helps.
If that doesn't work, try going to the user that's have the issue then select from the top of Blender
File -> Defaults -> Load Factory Settings
then re-enableBool Tool
and see if it works then.The
step will reset all user preferences you've saved for that Windows user until you next open Blender, unless you save your preferences after selecting it.Added subscriber: @PratikPB2123
