Regression: Set curve radius does not work #90063
10 Participants
Reference: blender/blender#90063
Operating system: Windows-8.1-6.3.9600-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 660 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.47
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-07-22 22:44, hash:
fafd21b14c
Worked: 2.93.1 (but…)
Caused by
eb06ccc324
Expected: works after pressing {key Enter} (applying existing value), works after entering value and pressing {key Enter}
2021-07-23_05-26-16.mp4
The radius of each point on the curve should be 1.0, but nothing has changed.
untitled.blend
Added subscriber: @Vyach
#91657 was marked as duplicate of this issue
Can not reproduce with present 2.93.2 build. Can replicate only with 3.0.0.
Will bisect to find the culprit.
Caused by
eb06ccc324
Regression: Set curve radius do not workto Regression: Set curve radius does not workAdded subscribers: @MikhailRachinskiy, @HooglyBoogly
Additional feedback: editing operator property should not be required, operator should execute on call. As it is primarily used to reset radius, values other than 1 will not be used as often.
Added subscriber: @mano-wii
This is a regression, so I believe it's valid to set it as high priority.
Is this still an issue? In my test the behavior in 3.0 seems to be the same as in 2.93 now, but maybe I'm missing a case.
Added subscriber: @dfelinto
Since this is not blocking I'm setting it as 3.1. Note: I did not test, so I don't know if the issue is still around.
Tested to be sure. Yes, issue still here. Plus new detail: blender do not react to same value, but reacts to changed one.
2021-11-25_15-03-36.mp4
This issue was referenced by
3bf10e5d0a
Tested again. It works, but do not react to Enter immediately
2021-11-28_17-50-39.mp4
And yes, it worked with enter immediately with b2.79
So there is still regression. Should I make new report?
2021-11-28_17-55-39.mp4
Added subscriber: @1D_Inc
There are two non-graphical widespread systems that allow to enhance workflow - a hotkey/shortcut system (Blender, Maya, 3dsmax) and aliases system (AutoCAD, Revit)
In Blender the keymap represents the first enhancement system type, and the operator search pop-up is able to represent the second enhancement system type.
So indeed, this is important.
@Vyach please remember always be explicit about which version you tested.
I tested here with
d2e6087335
and it seems fine. It is the behaviour you described, but we had this already in 2.93.There is something strange with that file by the way. I think it is corrupt to some extent. If I slide the radius button to change the radius and then cancel, the curve is "fixed" (same effect as if I set the radius to 1.0). But again, this happens in 2.93 as well.
If you think this is still a bug (and can trace back what was the last Blender that was working) better to report as its own issue indeed. Since the original bug (the one introduced after 2.93) was fixed.
Okay, will do.
2.93 and 3.1 do not react to Enter. Will make new report then.
@dfelinto #93578 (Regression: Set curve radius. Operator/window do not react to Enter immediately)
done
