Blender messes up with framebuffers in custom OpenGL renderer #90116
2 Participants
Reference: blender/blender#90116
Operating system: Linux-5.8.0-63-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.91.03
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash:
84da05a8b8
Worked: None. Does not work on 3.0 neither
Custom OpenGL-based renderer is inconsistent when using complex framebuffers. Result depends on blender window configuration and context.
Install
pyopengl
module for blender's python withpip install pyopengl
Open attached
renderengine_bug.py
in blender and run the scriptrenderengine_bug.py
It will add a custom OpenGL-based renderer called GLRender in Blender's UI.
Try to render with
bpy.ops.render.render('EXEC_DEFAULT')
from Blender python console. It should render and after completion create 3 images corresponding to different outputs of fragment shader. Note that they all have different types - vec4, vec3 and float.If you try to repeat that with Image Editor opened then for some reason only first attachment of the framebuffer seems to be drawn into, so images gl_1 and gl_2 are empty. If you have 3d viewport opened then again, everything renders as it should.
Rendering with
bpy.ops.render.render('INVOKE_DEFAULT')
always works fine.So for some reason, the result of my OpenGL renderer depends on a window configuration of blender. So I might assume that some color attachments are reserved by blender or something. I am not 100% fluent with OpenGL, but when trying this code in a standalone python, everything is consistent.
Also note that attachments which have type vec4 are always rendered fine. So if you try to change type of col1 or col2 to vec4 and change fragment shader correspondingly, they are always render as should. So the problem is present only for outputs with types float, vec2, vec3.
I also uploaded a video demonstrating the problem:
2021-07-25 11-23-02.mp4
I have an almost exact renderer using blender's
gpu
module, where multiple framebuffer attachments works fine. I still cannot use that module completely as extracting data from gputextures to blender images is super slow compared to pyopengl+numpyAdded subscriber: @blendersamsonov
Added subscriber: @OmarEmaraDev
I either get corrupt data on the second and third attachment or I get zero data in software mode.
I am not sure if the code is correct to classify this as a bug, however.
All your attachment textures have a type of
GL_RGBA32F
but you write float and vec3 outputs in the fragment shader. Is that correct?Can you also attach the gpu module version of your script?
Just a poke regarding my inquiry above, otherwise we will have to archive this for now.
