Blender 2.90.0, 2.92.0, 2.93.1, 3.0.0-alpha master and 2.80 crashes when Cycles Render Devices is set to OpenCL #90315
Reference: blender/blender#90315
Operating system:
Edition Windows 10 Pro
Version 21H1
Installed on 06/29/2021
OS build 19043.1110
Experience Windows Feature Experience Pack 120.2212.3530.0
Graphics card:
MSI Gaming X Trio AMD Radeon RX 6900XT
Radeon Software Version: 21.7.2
(Issue also occurs in version 21.7.1; Just updated to newest version in hopes of fixing the issue)
CPU: AMD Ryzen 9 5950X
Broken: 2.92.0, 2.93.1, 2.90.0, 2.80
Worked: None so far
The application immediately crashes when Cycles Render Devices is set to OpenCL. The application will on occasion may crash without warning even without interacting with such settings.
Version 2.80 is the most prone to sudden crashes and may crash upon performing Edit -> Preferences -> System on startup.
For versions 2.90, 2.92.0, 2.93.1, 3.0.0-alpha master, tool icons, such as Move tool will experience graphical distortion and artifacting upon startup sometimes.
Windows Event Viewer and Reliability History only records the application crash for version 2.80. None of the versions tested have generated crash logs under C:\Users\user\AppData\Local\Temp - No text files have been found.
I have run Opendata blenchmark successfully in the past using version 2.92.0:
https://opendata.blender.org/benchmarks/b210d419-e292-4f5a-b219-70635be5abef/
On Startup:
Edit -> Preferences -> System -> Cycle Render Devices -> OpenCL
Edit -> Preferences -> Add-ons -> Install results in a similar issue as well. At times Edit -> Preferences -> Add-ons is already enough to cause an undocumented crash that does not generate any .txt crash logs.
blender_debug_output.txt
blender_system_info.txt
Added subscriber: @Frederick-Tian
Blender 2.92.0, 2.93.1, and 2.80 crashes when Cycles Render Devices is set to OpenCLto Blender 2.90.0, 2.92.0, 2.93.1, and 2.80 crashes when Cycles Render Devices is set to OpenCLBlender 2.90.0, 2.92.0, 2.93.1, and 2.80 crashes when Cycles Render Devices is set to OpenCLto Blender 2.90.0, 2.92.0, 2.93.1, 3.0.0-alpha master and 2.80 crashes when Cycles Render Devices is set to OpenCLAdded subscriber: @PratikPB2123
Thanks for the report. I can not reproduce the crash on master:
5116b7a4c2
Please start blender with
blender_debug_log.cmd
. After the crash it will generate two files in windows explorer. Add both the files in this thread.System Information
These logs are from version 2.93.1
These logs are from version 3.0.0 alpha master
Thanks for the file. Information given in the log files is not useful.
Does the crash happens right after opening the explorer? Also is it a crash or just blender freezes for a long time?
Can you please add a short video to describe the crash steps. I can not reproduce the crash with present given steps :)
First recording:
2021-07-30_14-50-27.mkv
Second recording:
2021-07-30_14-53-25.mkv
Either one happens at random. Do you want me to keep attaching the debug log files even if they are not providing anything useful?
I've been also having other applications crash lately as well:
Here are the logs from Microsoft Event Viewer:
Faulting application name: CLIPStudioPaint.exe, version: 1.10.13.0, time stamp: 0x60cac8f2
Faulting module name: ntdll.dll, version: 10.0.19041.1110, time stamp: 0xe7a22463
Exception code: 0xc0000374
Fault offset: 0x00000000000ff259
Faulting process id: 0x1aa8
Faulting application start time: 0x01d7849c1ae0e524
Faulting application path: C:\Program Files\CELSYS\CLIP STUDIO 1.5\CLIP STUDIO PAINT\CLIPStudioPaint.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: a41258b4-6c8c-4db3-9648-da89b18a5998
Faulting package full name:
Faulting package-relative application ID:
Faulting application name: CLIPStudioModeler.exe, version: 1.10.13.0, time stamp: 0x60cb94ca
Faulting process id: 0x3bd0
Faulting application start time: 0x01d7849807147046
Faulting application path: C:\Program Files\CELSYS\CLIP STUDIO 1.5\CLIP STUDIO MODELER\CLIPStudioModeler.exe
Report Id: 3dea8718-3a95-477d-a22a-f62e32e47bd4
Faulting application name: Roland Cloud Manager.exe, version: 0.0.0.0, time stamp: 0x60afaa71
Faulting process id: 0x3a28
Faulting application start time: 0x01d7857db58f80c7
Faulting application path: D:\Relocated\RolandCloudManager\Roland Cloud Manager.exe
Report Id: e5f51f95-298d-4519-97d8-98fb40dd0400
The program blender.exe version 2.9.3.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Process ID: 1df4
Start Time: 01d7857c91c92623
Termination Time: 3
Application Path: D:\Relocated\Blender Foundation\Blender 2.93\blender.exe
Report Id: bdf5addf-dfd2-48c2-abc0-1740f3c19b0d
Hang type: Unknown
Faulting application name: blender.exe, version: 2.8.0.0, time stamp: 0x5d3f1481
Faulting process id: 0x1438
Faulting application start time: 0x01d784ca86d25154
Faulting application path: D:\Relocated\Blender Foundation\Blender\blender.exe
Report Id: 6a7bc604-acb5-40af-9171-b09e14fd6441
Could all of these be related to each other? I am not too sure as to what C:\Windows\SYSTEM32\ntdll.dll does or how it interacts with the crashing applications.
Added subscriber: @StephenSwaney
ntdll.dll is fundamental part of your operating system. Lots of things crashing there make me suspect either a broken operating system install or a hard drive going bad.
Reformatted my OS drive and reinstalled Windows. As of now, everything is working as expected.
PSA: If your Windows installation ever crashes partway, reformat and reinstall it again - even if it looks like it's working fine. The command line tools to fix such issues that Microsoft provides are POS and don't do jack. I can't believe I never encountered the ntdll.dll error earlier (would also have saved me the time and trouble of reinstalling everything if it didn't just decide to show up ~30 days after installation to screw me over)
After the clean reinstall, my computer runs ~4 - 5 degrees Celsius cooler and my monitor no longer shuts itself down when idle (when Windows Power settings are set to never turn off the display or go to sleep).
I apologize for posting a non-Blender bug report.
@Frederick-Tian , will close if problem is fixed.
@StephenSwaney , thanks! :)
