Video editing preview: unable to select source video channel #90442
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
5 Participants
Reference: blender/blender-manual#90442
Operating system: Arch Linux
Graphics card: GeForce GTX 1060 6G
Broken: Blender 2.93.1
Worked: n/a (never used blender before)
I am following the manual for MultiCam setup https://docs.blender.org/manual/en/2.93/video_editing/sequencer/strips/effects/multicam.html
However even after searching for 3 hours now, No selector in the "Preview" windows can be found to select the channel being displayed.
See attached screenshot:
The two preview views always show same video clip, I would like to configure it to display one of the channels each as described in the documentation step 3.
I would expect the documentation for MultiCam editing to be more precise on how to do step 3 "Add a viewer region for every input channel and to improve the performance use proxies."
Follow the Workflow described in official multicam documentation: https://docs.blender.org/manual/en/2.93/video_editing/sequencer/strips/effects/multicam.html
Added subscriber: @Rainer
After some more search, I finally found the documentation for Sidebar: https://docs.blender.org/manual/en/2.93/video_editing/preview/sidebar.html
I Found Channel selector then via:
So I think the documentation needs updating, as this is not documented in MultiCam Documentation https://docs.blender.org/manual/en/2.93/video_editing/sequencer/strips/effects/multicam.html
I expect a reference there to https://docs.blender.org/manual/en/2.93/video_editing/preview/sidebar.html to make this more easy to be found.
Added subscriber: @tintwotin
How would this UI solution work for you? https://developer.blender.org/D10521
Hi, Thanks for the reply, This PR of yours quite directly addresses my problem by making the workflow very intuitive.
In this case documentation would be not so important as it is in the current very hidden implementation :)
This issue was referenced by 8281
Added subscriber: @iss
@iss For the record, I'm not convinced that the above UX problem can be solved by documentation alone.
