Period After Folder Name in Output is not blocked! #90444
7 Participants
Reference: blender/blender#90444
Operating system: Windows 10
Graphics card: GTX 1050
(Important Notice: All Hardware has this issue. It is software based!)
Broken: (1.60 - 3.0)
Worked: (None)
When saving an image sequence, if folder has more than one period at the end, it gets saved and Windows cannot deal with that folder.
Step 1: Go to the Output Properties Panel
Step 2: Type /tmp/YourFilenameWithThreeDotsAtTheEnd...
Step 3: Hit the Render Animation button
Result
You now have a folder on your Windows Computer that is impossible to open or delete or do anything with because it has an invalid filename that has a compatibility issue left over from the early DOS days. This is a severe issue!
Thanks!
Added subscriber: @BlenderBach
Added subscriber: @iss
This will probably be issue in more places than render output.
Added subscriber: @Harley
Hmm.... if you choose to make a folder that ends in dots then can always remove it like this:
Added subscriber: @LazyDodo
This comment was removed by @LazyDodo
Added subscriber: @kursadk
Isn't it a user responsibility to conform the OS requirements when it comes to file and folder names? Blender is not at fault here as far as I can tell.
I have confirmed this, because we have function
BLI_filename_make_safe
so it can be used perhaps with RNA set function. Path would be sanitized if you would enter it through file browser. In this case, path is also ammended, but there is report for that too - #88193Yes, I know that. However, not everyone is a tech wizard. There should be some kind of emergency name filter put in place that forcefully removes the periods so someone doesn't mess up by mistake.
Actually, every normal software has a special block filter that tells you that it can't use this filename because it is invalid for the Operating System. Blender should also have a special blocking filter so no one makes a mistake, and then freak out that they have folder that is impossible to delete or use. (I know how to interface with these folders via command line, but not everyone does). I suggest adding a special force name block so this doesn't happen to unsuspecting users... Remember, Windows is not Linux. Linux supports these things because Linux was designed differently. Windows, on the other hand, uses compatibility with DOS, which in turn has many issues. Unfortunately, Blender isn't nearly as good with Windows as with Linux since from TRACES (Blender's Predecessor) that worked on Amiga Workbench OS (UNIX based OS) all the way to Blender 1.60 they all used UNIX and Linux based Operating Systems, so they were all to work better with that. Windows was a later port and since it was just an afterthought, there are still some bugs that need to be ironed out to have a perfect Windows compatibility...
P.S. So far, I have been impressed by Blender for many years. In all of my 6 years of Blender, this is my first ever Bug report. Amazing!
SEVERE!!! Period After Folder Name in Output is not blocked!to Period After Folder Name in Output is not blocked!Added subscriber: @zanqdo
If such a sanitizer is implemente it should better be a part of the file saving operation, otherwise (like in my report) it could block perfectly valid filenames
What I mean is that it should always look at the first and last characters. If one of them is a period, it should just automatically change it to an underscore as an emergency to avoid issues. This way the filename remains intact, and only the period gets removed.
The problem with that is Blender doesn't know if the last thing in your path is the full filename or is gonna get extended by the numbering and extension.
Something like File. can be perfectly valid it it's gonna be written as File.001.png
So basically the sanitizer needs to be smarter than just checking the last character of the path.
They got to do something... I'm not the programmer, I'm the "Dumb Monkey Tester"
Added subscriber: @ideasman42
It's not obvious what an ideal solution would be in this case since files may be saved on Linux/macOS where this isn't a limitation.
Any logic that changes the output directory from the one that's requested could cause problems for rendering utilities that scan the output directory later on.
This will be an issue for any part of Blender that makes directories, not just rendering (off the top of my head...) unpacking files, generated proxies, point-cache.
This is exactly another reason why I hate Windows. (Or as I like to call it, "Obnoxious OS")
Realistically though, this doesn’t seem to be critical
In a nutshell, this naming IS supported by the Windows file system, but is just not handled well in the Windows UI. The same thing can happen with files or folders that end with a space.
Ultimately it might be best to simply do what the user asked to do rather than guess at their intentions and disallow behavior that could be intentional for someone else. Sometimes the best answer to “it hurts when I do this” is “then don’t do that”
Please bear in mind that this report assumes everything is happening under windows with local drives. What if the user is setting such folder on a Samba network drive where the files will be later used by on a Linux Pc that has access to those folders?
I do not see why Blender needs to bend backwards to try to catch all possibilities with all file and folder names issues.
Closing this report as it doesn't seem practical to attempt to prevent this situation from happening, especially when this is not a common problem that users face (as far as I know this is the first time it's been reported).
