Some UI element are missing in UV editor
Confirmed, NormalPublic
Operating system: Windows 10 21H1
Graphics card: GTX 1660S
Broken: 2.93.2
Worked: unknown
There is a python error and some UI element are missing from UV editor.
  1. Open this blender file, this is my current project with everything removed expect the default cube and UV editor opened.
  2. Save the blender file somewhere.
  3. Ctrl+s (to save it with the shortcut)
  4. Tab to edit mode.
  5. Tab to object mode.
  6. Blender drop python error probably because the UI is missing.
If not working, repeat the steps 3-4-5 consecutively and the error should appear.
Thank you for taking over!
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.Aug 13 2021, 5:16 AM
Can confirm on blender-v2.93-release branch build. Issue also happens on old 3.0.0 builds.
Will find the commit to backport
Problem was fixed on master branch with the commit rBea43ae4194e293599997f1d0d47430b462b4fd7f.
Not sure if it's required to backport this commit.
Edit: Will check again if the mentioned commit is correct (May be I did a mistake when bisecting)
