GPencil: Ghost point on selection #90742
Reference: blender/blender#90742
Operating system: Linux-5.10.0-6-amd64-x86_64-with-glibc2.31 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.73.01
Broken version: 3.0.0 Alpha, branch: master, commit date: 2021-08-17 18:20, hash:
88dc274d05
Broken version: 2.93.0 Beta, branch: master, commit date: 2021-04-21 20:15, hash:
0f66dbea90
Broken version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
Broken version: 2.83 and up
Worked: 2.82
When selecting with box select, sometimes a weird point appears and stay until you want to take a closer look, but then it vanishes again. It appears to be sometimes black, sometimes orange and sometimes gray. Here are some screenshots:
The orange dot is not the origin, but at that location. I have also seen it jump to other places when selecting or even when doing completely unrelated things, so it seems to be a memory issue. Blender does not report unfreed memory in the console though.
Here is also one that appeared during weight painting, so it is colored, but this time neither at the origin nor in the drawing plane:
From here there are several ways to recreate it. Everything that triggers a rebuild in editmode works.
Was able to recreate this in a different file as well using the Stroke Primitive Object like in the screenshot.
Simple way to reproduce is: toggle edit mode
Blender 2021-08-18 12-05-21.mp4
Added subscriber: @HDMaster84
Grease Pencil ghost point on selectionto GPencil: Ghost point on selectionAdded subscriber: @antoniov
I cannot reproduce on my system and never noticed before this bug.
Can reproduce on master with described steps:
24c16f5457
Simple way to reproduce is: toggling edit mode
{[F10287251](https://archive.blender.org/developer/F10287251/Blender_2021-08-18_12-05-21.mp4)}
(video Added in task description)Changed status from 'Needs Triage' to: 'Confirmed'
Might be caused by D8660, can't test that right now though.
I tried debugging it more using Overlay > Stroke Direction, and found that for all the cases where I got it, it was a red dot -> endpoint of a curve. I only got it about 5 times in total though, so might not be for certain.
It seems to be some uninitialized data in the VBOs passed to
edit_gpencil_vert.glsl
Added subscriber: @fclem
@fclem Do you have an idea what could cause this?
Figured it out. @antoniov if you try this patch you should be able to see the ghost appear:
The problem was that on the first vertex which is there for technical reasons the material was not initialized to -1. So a simple fix here is:
@PratikPB2123 I cannot reproduce it...could you test the fix? For me the fix is logic, but I cannot test it.
@fclem do you see any problem with the proposed fix?
Hi @antoniov , this is something I tried on lite debug build (will try with full build) and issue does not happen even without the proposed fix.
Also: Can not reproduce with 2.92 (
2021-02-24
) so I don't think mentioned patch is the actual cause for the issue@PratikPB2123 It's probably caused by D6293 which introduced that file. The best way to recreate the issue seems to be duplicating all strokes, since it is likely to be using to a new memory location in that case. That way I could even recreate this issue in 2.90.1 and 2.83 but not in 2.82
This issue was referenced by
e76f04c870
