Action editor doesn't switch to new action until you add keyframe #90882
2 Participants
Reference: blender/blender#90882
Operating system: Windows 10
Graphics card: 3090
Broken: 2.93.2
Worked: -
I have two actions on a character. But switching between them in the action editor and then scrubbing on the animation timeline continues to play back only the first action.
What I don't understand is that this can't be replicated in a new file. In a new file, switching actions behave as expected and the workaround below fixes the issue even for this file. But how did this error creep into this file and how come it's even saved with the file?
GoodGuildLeader004.blend
Results
Regardless of animation chosen, only ArmatureAction.001 plays.
Expected
The animation for the chosen action should play.
Workaround
If you switch to GoodGuildLeaderIdleSittingAnimation and insert a new keyframe, Blender catches on and switches to that action.
Added subscriber: @RobertS
Added subscriber: @lichtwerk
Not quite sure I understand correctly:
GoodGuildLeader.001
is selectedGoodGuildLeader.001
has no armature, it does have the actionGoodGuildLeaderIdleSittingAnimation
associated, but this wont have an effect (since the action needs to be on the armature)GoodGuildLeader
(or more precisely its armatureGoodGuildLeaderArmature
-- which has theArmatureAction.001
action associated)GoodGuildLeaderIdleSittingAnimation
action only has a single keyframe (no animation to see here)I can do the following:
action fromGoodGuildLeader.001
mesh (does not make sense here)GoodGuildLeaderArmature
and switch between the two actions with no problems (they updae immediately)Dont see a bug here, is this a misunderstanding? Does this work for you?
Thanks for looking into it. I tried to follow what you described, but unfortunately it did not work for me:
The image below does indeed seem to indicate that the action in question is associated with two models and one armature. The reason is probably because GoodGuildLeader.001 is simply duplicated.
So as noted, GoodGuildLeader.001 should not use it (as I removed the armature from it earlier). In order to remove the action from GoodGuildLeader.001, I follwed the exact steps you do for removing a material from a model. I selected the model, went to the appropriate editor, and clicked X on the thing I wanted to remove.
But after doing the above, the outliner still looks the same. There's still lots of animations associated with GoodGuildLeader.001, which means that the procedure for removing them is different than with materials (which seems like inconsistent ui design). You also can't go into the outliner and delete them (the option simply doesn't exist), and the data api doesn't seem to provide any list of users either (only a count).
So now I had to turn to web searches to find out how this is done, which unfortunately didn't help. The Blender documentation however indicated that there was a sidepanel menu (hidden, as usual in Blender), where you could also find the actions. However, reading that panel doesn't seem to indicate at all that GoodGuildLeader.001 is in any way associated with them and removing them from there seems to have removed them from the entire document.
So yes, there might not be a bug here, but from a UI standpoint, I'm completely lost as what to do next and I feel that I didn't get any help from the UI itself, and worse, even after undoing the step above that seemingly removed the actions completely, and my document now looking as in the screenshots still, neither of the two models in the document now animate when I scrub the animation timeline.
Oh, and after just deleting all the actions using that side menu, and attempting to create a new one having the correct model selected, I get the following when I want to add keyframes:
I know Blender developers despise anything that has to do with UI design in bug reports, so I'll try asking in the BlenderArtists forum instead.
Yes, removing the Action can be done via the X.
However, your screenshot indicates the Action has 4 users
When opening your file, the action has 2 users (so not sure what you have done, please try this with exactly the file you have shared here)
The remaining actions associated with
GoodGuildLeader.001
are the result of them being used in the NLA Editor https://docs.blender.org/manual/en/2.93/editors/nla/introduction.htmlIf you want to get rid of them as well, go to the NLA Editor [remove all clips, tracks, possibly call
Edit
>Remove Empty Animation Data
], traces of animation will then be gone onGoodGuildLeader.001
.Which panel / side-menu is this? Is this from an Addon?
Regarding the side-menu, I'm sorry but yes it appears it is from an add-on. I mixed it up because the documentation said "sidebar" and not side-menu (https://docs.blender.org/manual/en/latest/animation/actions.html).
But that aside, opening the attached .blend again, you are correct that deleting the actions, as you do with materials, seems to remove them from GoodGuildLeader.001, but there also seems to be residue entries in the outliner under NLA Tracks that I can't get rid of (as if once they're there in the outliner, they're always there). I made a video of what I'm experiencing this time:
https://www.youtube.com/watch?v=ow4ejtCXnvU
Now, I suspect it's at the last step above I'm missing something, and I think part of the original confusion is that at some point before saving the file, I hit the "push down" button which I shouldn't have.
GoodGuildLeader005.blend
Finally, to further confuse the situation, as mentioned I did continue working on the file which is why the Action had 4 users as you noted, and the error message with "No suitable context info for active keying set" comes from that file which I attach here. If you open that file, add an action and attempt to add keyframes, that message pops up.
Delete the tracks as well (left hand side in the NLA, the tracks can be selected an {key X} will remove them, then
Edit
will get rid of the rest)You are still trying to use an armature action on a mesh object: wont work (the mesh does not have all the FCurve paths referring to bones), select the armature instead.
If I open that file finally we have an action on an armature (good). Inserting keyframes (e.g. rotation) is not a problem then.
Think at this point we have to close this report since none of these things are bugs.
