Bug when working with the Child Of constraint and the Selection to Cursor command #91079
Reference: blender/blender#91079
Broken: version: 3.0.0 Alpha, branch: arcpatch-D6110, commit date: 2021-08-25 13:28, hash:
6e57bc2a4e
Worked: Never
When working with the Child Of constraint the
Select To Cursor
command does not work correctly.Exact steps for others to reproduce the error
Select To Cursor
Bug_ChildOf_Selection2Cursor.blend
Original Report:
When working with the Child Of constraint, it is impossible to use it several times by enabling and disabling the influence of the constraint.
He second time the offset is different and the child object jumps away from the desired position.
It's hard to put it in the right place. I tried to use a 3D cursor for this, but the Select To Cursor command does not work correctly when working with this the Child Of constraints.
Added subscriber: @bel.petr
Added subscriber: @iss
This sounds more like workflow issue than a bug.
If you think this is bug, please provide steps to reproduce the bug.
If this is workflow issue please consult this issue in community websites: https://www.blender.org/community/
I have uploaded a blender file. Try to bind the pyramid in frame 175 so that it does not roll to the side. I could not. Also, I could not set it off either to the 3D cursor, or to an empty object.
I also uploaded a video file in it showing the process and the problem associated with it.
https://youtu.be/2BSLMw14JTA
Bug_ChildOf_Selection2Cursor.mp4
Added subscriber: @mano-wii
Ok I understand now what you are trying to do. In video you keyed visual location with modifier disabled, then when you enable modifier it will jump. that is not a bug because visual location is same as actual location with modifier disabled.
I think, that snapping should work in this case, but not sure. @mano-wii can you check?
Added subscriber: @ThirtysixLab
Hi. May I take part in the discussion? ...
The 3D cursor must always be in a visually correct position in the world - otherwise, for what need (3Dcursor to selected) !!!
Ideally, the cursor should also receive angles degrees, so that later the object can be positioned with angles by (selected to 3Dcursor). - but it will probably be in version 4.00 ))
This is indeed a bug.
D7780: Transform: Replace View3d Snap operators with a transform ops version is a patch that would solve this problem.
This function does not work for me in version 2.9
It appears the bug has been fixed already.
Please try the latest daily build: https://builder.blender.org/download/
If the problem persists, please let us know so we can re-open the report. Don't forget to mention the specific version you tested again.
