Pose Bone Selection, Slow Since 2.8 #91253
6 Participants
Reference: blender/blender#91253
Graphics card: NVIDIA GeForce GTX 1650 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.68
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-08-23 15:09, hash:
7d17f2addf
Worked:
e92f235283
When you click to select bones in pose mode (without box select), there is a delay in Blender updating.
It's unnoticeable with around 40 bones but if you have like 250+ bones, it because more and more laggy.
It speeds up if you hide bones or use another display type other than envelope.
However even if you set the display type to Wire and used meshes on all the bones, it would still be faster than Octahedral
bones.blend
2021-09-08 03-53-25.mp4
In this video, first I show clicking bones in 2.78 (I don't have 2.79 but I'm sure it works there as well),
then I show clicking Octahedral bones in 3.0/master, with it freezing a couple of times.
Next I show clicking Wire bones, and finally Wire bones with a mesh (based on Octahedral) as their custom shape
I didn't record it but 2.7 is only slow when showing all 3 objects (3x bone count), whereas 3.0 only gets that additional lag when they're all in pose mode (which affects the Wire rigs).
Added subscriber: @Phigon
As a test before I opened 2.7, I made an addon operator to simulate the bone clicking, using the box select operator, and not only does it get back the near-instant click of 2.7, it performs fast when having all 3 rigs in pose mode.
My point being that box/circle/lasso select are fast and
bpy.ops.view3d.select
/VIEW3D_OT_select
is just needlessly slower, and apparently has been since my earliest version of 2.8 (9a85592dde
), or at least it's been broken in every version that I've rolled back to for this test.Pose Bone Selection on Octahedral, Slow Since 2.8to Pose Bone Selection, Slow Since 2.8Added subscriber: @Jeroen-Bakker
Added subscriber: @Jibril-Omukama-Isimbabi
I have the same problem. Since 2.8 Blender has been becoming more and more unusable. I have the same problem with bone selection, blender progressively slows as you I use it. All of this is not dependent of scene complexity as it happens on simple scenes too
Whenever I have a problem with Blender's operators/ui, I report if it seems unintentional and make a fix/alternative via python until someone maybe decides to fix/change it internally.
If you want, I can give you the code from my addon to do the fast selection. For anything else, I can't help there (unless I made an addon for it)
Yes please. I'm willing to try anything. Since it works for you, it'll probably work for me. This issue causes me so much time.
Added subscribers: @ideasman42, @mano-wii
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
This seems to be related to the "OpenGL Depth Picking" option (
On
by default from 2.80 onwards).Comparing 2.79 with 3.2: selection in 2.79 with with "OpenGL Depth Picking" is equivalent to the 3.2 with this option disabled.
From fastest to slowest we have this order:
This problem reminds me of this other report -> #95130 (Annoyingly slow selecting (>2 seconds), but everything else is buttery smooth and responsive)
There is also a
ToDo
related to this issue -> #68989 ( Selection future-proof design)I imagine that all these reports should be merged in the
ToDo
(#68989).@ideasman42 if I'm not mistaken you worked on the "OpenGL Depth Picking" option, is this regression a Known Issue?
pose_select_fast.zip
I was thinking I could just cut and paste batches of code to make an addon but I didn't feel like backtracking through my code to strip only the needed material, so I just snipped the pose code as an addon and included my module with it.
Install instructions included.
Thank you. I'll try it out
@Phigon can you confirm that disabling "OpenGL Depth Picking" resolves the issue? If so, how much is the performance improved?
Disabling it, I can do the Shift+Click rainbow selecting, as attempted in the video.
My eyes aren't fast enough to tell whether or not my box-select addon-version is faster.
I don't know if I'm seeing a lag or I'm imagining it. The only verifiable metric I can say is that it's not slow/freezing on the 900 Octahedral bones I'm selecting.
@ideasman42 Disabling OpenGL Depth Picking doesn't work for me at all. I've cleared prefs, restarted projects, reinstalled. I even reinstalled my OS
@Jibril-Omukama-Isimbabi do you mean it isn't faster? or selection doesn't work at all.
If picking doesn't work at all, do other selection methods also fail? (box selection etc).
@Phigon to be clear, when "OpenGL Depth Picking" is disabled, selection is working fast and correctly for you (as you would expect).
Here is a patch to address this issue but would still like to understand the problems you're running into: D13990.
@mano-wii It's known that reading the depth buffer doesn't have great performance, OTOH, there have been changes/refactoring since 2.8 which may have made the situation worse.
I've been looking into this area recently and there are a few ways to improve performance here.
Okay, I just retested this. My box selection version IS faster. This time, I had a youtube video playing, when trying without OpenGL.
With OpenGL, blender will visibly pause and possibly freeze [Not Responding].
Without OpenGL, while selecting bones fast, blender would pause (not show any visual updates) before updating the selection of like 3-5 bones. It's definitely usable enough to forget it's a problem but it's still a problem.
Whereas using box-select is essentially instant, with or without video playback. (my addon executes box-select then deselects bones, to mimic the click-select)
This issue was referenced by
3267c91b4d
Changed status from 'Needs Developer To Reproduce' to: 'Resolved'
I was going to report that it was still slow, even if I disable OpenGL, so it should be at least put on a todo list instead of closed but then I saw that 3.1 (
d1202bd641
) does not have this commit. Only 3.2.@Phigon can you confirm this is fixed in daily builds?
Definitely.
I took it from 320 bones to 2560. It was fast. It was taking too long to duplicate the bones in edit mode so I duplicated the object 3x for 7680. Fast.
In 3.1 it freezes with OpenGL and stutters without. It's even slow selecting the objects.
Just to push it, I duplicated it for 30720 bones, and that's when it starts to lag but that's mostly because of the bones overlapping (and it being harder to find an angle where they aren't, to test it).
