Random Number node #91373
5 Participants
Reference: blender/blender#91373
Since we remove the
Attribute Randomize
node, we need a viable alternative to generate random numbers based on a seed. This node might replace or extend the Random Float node.It's unclear whether we want different nodes for different data types or a single node for all data types.
Other related topics:
Added subscriber: @GeorgiaPacific
Added subscriber: @CharlieJolly
Some thoughts:
Added subscriber: @Eary
I like the checkbox but not sure about hiding the seed value. I previously discussed this in the devtalk thread:
https://devtalk.blender.org/t/fields-and-anonymous-attributes-proposal/19450/148?u=eary
I also mentioned a checkbox for making it output a field instead of a constant, but the reason for this thought was "connect the index to the seed is actually not ideal, since you just lose the control over the seed by doing that." For example, you want two different random floats but their max and min are the same range, you would still need to manually change seed, and if you hide the seed value, that's more of a pain in this situation.
I would suggest instead of hiding the seed value after checking the box, simply change the value from the seed itself to a "Seed Offset" after "Auto Seed" is checked, so it would be a field output that would have different seed based on the index, and the user can still control the seed's offset in an intuitive way.
If you think the naming to be confusing, then we can have the logic of seed offset under the hood but have the UI be, like the seed input would jut stay being displayed as seed, the checkbox can be named "Field", or if you are not comfortable exposing the field term in the interface, maybe "Constant" and have it checked by default. Once you uncheck it, the node will auto seed it under the hood and outputs a field. The seed input would just stays the same in the UI while actually being an offset of the actual seed. If you don't like the checkbox to be named "Constant" then we can figure something else but the central idea is the seed offset.
Added subscriber: @SimonThommes
Following the outcome of the design discussion:
I didn't have a chance to participate myself and am largely happy with what was decided.
There is one thing I do want to point out though that I would really change about the node and that is the naming of the seed inputs.
The decision was to call them
Seed 1
andSeed 2
, while seed 1 is prepopulated with the Index field as default.Stable ID
naming of the point distribute node output makes its functionality clear enough to not default to a stable id in the random value node. the same naming logic should apply here, in my opinionFor all of those reasons I propose to call the first seed input
ID
instead. That marks it clearly as an identifier, which it is. Same ID results in same random value. And it does not narrow it down do be an index or an integer, so it is general enough. But it communicates much more clearly how it is utilized (by default).I like it. So there will be an
ID
input that has Implicitindex
field, and aSeed
input with a slider. This sounds good.Changed status from 'Needs Triage' to: 'Resolved'
