Grease pencil Time offset modifier crash #91454
Reference: blender/blender#91454
Operating system: Windows
Graphics card: RTX2060 (notebook)
Broken: 2.93.2
Grease pencil Time offset modifier crash when create a loop and go to frame 0
It's working fine if I'm in Frame 1- 200 and so on.
create grease pencil object
Draw animation 10 frames
add time offset modifer > make it loop > custom frame range end at frame 12
go to frame 0
Blender will be very slow or crash.Ch010_Pg010_Pn010_Anim_bird_v09_scale.blend
Added subscriber: @Boat-Thawatchai-Chunhachai
Added subscriber: @antoniov
Have you tested last build of 3.0? IIRC this bug was fixed in 3.0.
Oh, Thanks it' works perfectly on the latest version.
Next time I'll try out the latest one first.
Thanks a lot Antonio :)
after I try it again with the latest version of Blender 3.0 and if you scroll to time line back and forth before frame 1 (frame 0, frame -3,frame -5 ) Blender will sstart to slow down again.
Added subscriber: @lichtwerk
The crash was fixed by
af7233368d
, but I can confirm blender is kind of hanging in negative keyframes in this file (this was also the case prior tof3bf87e588
though)@antoniov: mind checking?
@lichtwerk I have removed all modifers except TimeOffset and the loop is "sometimes"... when I stop the running, the program is always in this section.
It looks some task locking not related to GPencil itself.
I can get the endless loop without any modifier.
Is this only in negative frames? mind sharing a file (without modifiers)?
Yes, only negatives using
master
compiled just now.The file:
Chicken_NoTime.blend
The video with the problem.
2021-09-17 12-11-00.mp4
@lichtwerk I have tested deleting both GP objects and when move to negative frames crash too.
Edit. False alarm.... it was slow, but no endless loop.
I hadn't seen the file has 2 GP objects and the othe rhas timeoffset too..if you remove the timeoffset of both the loop never happens...I'm going to do more tests
I have added some printf to this function:
deg::Depsgraph *deg_graph = reinterpret_cast<deg::Depsgraph *>(graph);
const Scene *scene = DEG_get_input_scene(graph);
deg_graph->tag_time_source();
deg_graph->frame = frame;
printf("a1->");
deg_graph->ctime = BKE_scene_frame_to_ctime(scene, frame);
printf("a2->");
deg_flush_updates_and_refresh(deg_graph);
printf("done\n");
Added subscriber: @frogstomp-4
@frogstomp-4 could you try if you can replicate this bug?
Could not reproduce in latest versions. The timeline is restricted so could not even scrub in negative frames.
Was this tested also agains latext 3.3 and above?
Hi, I saw this in my email. I tried this scene with the negative frames in Blender 3.3 and it doesn't slow down or crash anymore :)
I'm going to close this task. If you find again any problem, please open a new report.
