GPencil: Square type strokes do not react to Rotation option with Solid Shading #91467
Reference: blender/blender#91467
Operating system: Linux-5.10.0-6-amd64-x86_64-with-glibc2.31 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.73.01
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-16 14:11, hash:
73ed076489
Worked: ?
The stroke type Squares draw little squares at the points of the stroke. The rotation is controlled by the alignment option and the rotation slider, which in this case does nothing if solid shading mode is selected. Note that textures are not displayed in solid shading mode and even if used the squares don't rotate as long as I am in solid shading mode.
Added subscriber: @HDMaster84
Added subscriber: @antoniov
It must rotate the texture...check that.
2021-09-17 08-20-57.mp4
The bug is that it does nothing if the Style is Solid. If Texture is selected then it will look as if it rotates the square (not just the uv) so why won't it do that for the solid squares?
Also... neither the tooltip nor the documentation mention textures...
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
The option is in Fill mode, so no change in the geometry. The fix must be fix the tooltip. and disable the option if the mode is Solid Fill.
Edit. Sorry I was wrong...it's stroke... I need review all before doing any change.
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
Changed status from 'Confirmed' to: 'Needs User Info'
I cannot reproduce in my system...maybe I'm not looking the same.
2021-09-17 11-10-02.mp4
@antoniov Oh wow, this just became a lot more interesting!
You are explicitly showing that it works in solid shading mode. I figured out that it does actually work even on my system if I am in rendered mode, but it does nothing in solid shading mode.
Here is a Video of me doing the same:
2021-09-17_11-27-01.mp4
I will update the summary with the new information
GPencil: Square type strokes do not react to Rotation optionto GPencil: Square type strokes do not react to Rotation option with Solid ShadingI cannot reproduce in any Engine/Shading mode... could you test with this file?
Test_Rota_UV.blend
strange... I can not reproduce with that file.
Can you reproduce with this file?
gp_test_square_rotation.blend
I have seen where is the difference:
2021-09-17 16-49-23.mp4
Internally, the solid is just a texture filled of same color.
Actually the code is designed to use the rotation only in texture mode. As the Draw Engine is going to change with the new Eevee integration, IMHO the best option now is mark as KNow Issue and change the tooltip.
@HooglyBoogly Do you think the tooltip is correct now?
RNA_def_property_float_default(prop, 0.0f);
RNA_def_property_range(prop, -DEG2RADF(90.0f), DEG2RADF(90.0f));
RNA_def_property_ui_range(prop, -DEG2RADF(90.0f), DEG2RADF(90.0f), 10, 3);
RNA_def_property_update(prop, NC_GPENCIL | ND_SHADING, "rna_MaterialGpencil_update");
/* pass index for future compositing and editing tools */
I might suggest changing
valid
toapplies
, but sure, that makes sense.@HooglyBoogly Thanks, I have changed to
applies
.Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
