Rigify - new setup for connected neck & spine (Bug or a Feature?) #91474
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#91474
Graphics card: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.68
New behavior: version: 2.90+
Old behaviour: 2.83-
There is a difference in the way connected head + spine behave before and after 2.90. Here it is:
I can see this as a feature but the old behaviour also made sense. It would be nice to have it verified by someone who knows what's going on like @angavrilov or @icappiello
Create a Basic Human meta rig and generate it in 2.90+
Create a Basic Human meta rig and generate it in 2.83 or earlier
Move "tweak_spine.004" around and notice the difference between the two versions.
Added subscriber: @TodorNikolov
Added subscribers: @icappiello, @angavrilov
@TodorNikolov I believe that what was happening in 2.83 is worst compared to what happens in 2.90. I always found a bit limiting the usage of the neck tweak because of this propagated scale behavior. Can't tell though if this was a designed change or just a consequence of code changes. If you ask me, since now we have the unconnected option for the neck, I'd go for having the old 2.83 behavior when connected is on and the new 2.90 result when connected option is off (which I believe would happen by default).
@angavrilov what do you think?
Added subscribers: @Mets, @OmarEmaraDev
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Looks related to the change in
ba2521b7ed
. Is that the case @Mets @angavrilov?Changed status from 'Needs Developer To Reproduce' to: 'Archived'
Yep, it was an intentional change because the old behaviour seemed like it would be less often desired than the new one; propagating scale along the arms when squashing the upper body (or in the original case, when translating the neck FK), makes further posing on those arms annoying due to the way skewing affects transform operations.
There are arguments on both sides, so the old behaviour can still be achieved by parenting
shoulder.L/R
toDEF-spine.003
instead ofORG-spine.003
. This is easiest done by going on the shoulder metarig bones, enabling "Constraint Relinking" and then simply entering "DEF" in the "Parent" input box. Tooltip explains why this works.
