Geometry Nodes Instance Invisible in Cycles #91516
5 Participants
Reference: blender/blender#91516
Graphics card: NVIDIA GeForce MX130/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.96
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-18 19:45, hash:
bdbc7e12a0
No sure whether it is on the Cycles side or Geometry Nodes side. The instances are not visible in the final render, in the viewport you can get it to work by chance if you keep turning the Geometry Nodes modifier on and off. I just happened to get the bug and saved this file, I don't know how to reproduce it from startup.
Based on an attached .blend file
GN Geometry Instance Cycles Invisible Bug.blend
GN Geometry Instance Cycles Invisible Bug.mp4
Added subscriber: @Eary
Added subscribers: @brecht, @JacquesLucke
Don't have a full solution yet, but have some new info. Right now there are two problems:
Auto Smooth
option is set on the object. With this on, an assert is triggered inobject_to_mesh
.e57ce464c2
hid this assert at first.This second issue is fixed with the following patch. @brecht, does this look good to you?
Still have to investigate how the first issue should be solved.
Thanks, I committed that change along with avoiding the problem with auto smooth in this file. But this code is still weak and I think there are more bugs. I need to look into it closer.
@brecht Do you have a specific bug in mind that we can put in a bug report? Currently this task is marked as a high priority bug, but it is not really actionable for me.
@JacquesLucke, I have not had the time yet to investigate this more or confirm there are more issues. But the things I wanted to check:
I think these are mostly Cycles side things, so will lower the priority and remove the geometry nodes tag.
As far as I know, cycles shouldn't have to worry about converting curve objects to meshes anymore, since this is part of curve object evaluation-- if the curve object evaluates to a mesh, cycles will see a mesh object when it iterates through the evaluated objects.
Metaballs haven't been changed though, they will probably still need the displist -> mesh conversion.
Generally, when geometry nodes outputs a curve, it's really just a curve without any thickness. So it can't really be rendered. People use the Curve to Mesh node to give the curve a profile so that it can be rendered. This mesh will then be passed to cycles, not the original curve. Cycles does not have to do the curve-to-mesh conversion.
After all the latest fixes I think we can close this.
