Update nodes that realize instances. #91672
Closed
opened 2021-09-24 11:32:20 +02:00 by Jacques Lucke · 5 comments
Member
Nodes should generally not realize instances implicitly. Instead, they should either of the following two behaviors:
  • Handle instances in an explicit way. E.g. the Curve Fill node fills instances without making them real.
  • Create a warning and output an empty geometry when instances are passed in. An explicit Realize Instances node should be used instead.
The following nodes have to be updated:
  • Boolean: Fail when there are instances in the first input.
  • Distribute Points on Faces
  • Curve Fillet
  • Curve Length
  • Curve Resample
  • Curve to Mesh
  • Curve Trim
  • Material Assign
  • Material Replace
  • Mesh Subdivide
  • Triangulate
  • Mesh Subdivision Surface //Should be replaced anyway/
  • Curve to Points: Should be replaced by a node with outputs like point distribute anyway
  • Curve Endpoints: Should be replaced like curve to points anyway
  • Edge Split: Should be replaced by a node with a selection input anyway
Not quite sure if there are errors on this last. Some of the curve nodes may be deprecated already and don't need to be updated.
Explicit Instancing Proposal: https://devtalk.blender.org/t/explicit-instancing-proposal/20494
Meeting Notes on the topic: https://devtalk.blender.org/t/2021-09-20-2021-9-24-geometry-nodes-sub-module-meetings/20594/4
Nodes should generally not realize instances implicitly. Instead, they should either of the following two behaviors: * Handle instances in an explicit way. E.g. the Curve Fill node fills instances without making them real. * Create a warning and output an empty geometry when instances are passed in. An explicit Realize Instances node should be used instead. The following nodes have to be updated: - [x] Boolean: *Fail when there are instances in the first input.* - [x] Distribute Points on Faces - [x] Curve Fillet - [x] Curve Length - [x] Curve Resample - [x] Curve to Mesh - [x] Curve Trim - [x] Material Assign - [x] Material Replace - [x] Mesh Subdivide - [x] Triangulate - [ ] Mesh Subdivision Surface //Should be replaced anyway/ - [ ] Curve to Points: *Should be replaced by a node with outputs like point distribute anyway* - [ ] Curve Endpoints: *Should be replaced like curve to points anyway* - [ ] Edge Split: *Should be replaced by a node with a selection input anyway* Not quite sure if there are errors on this last. Some of the curve nodes may be deprecated already and don't need to be updated. Explicit Instancing Proposal: https://devtalk.blender.org/t/explicit-instancing-proposal/20494 Meeting Notes on the topic: https://devtalk.blender.org/t/2021-09-20-2021-9-24-geometry-nodes-sub-module-meetings/20594/4
Author
Member
Jacques Lucke changed title from Don't realize instances in various nodes to Update nodes that realize instances. 2021-09-24 11:56:28 +02:00
Member
Hans Goudey self-assigned this 2021-09-27 22:17:04 +02:00
Member
I'm still trying to understand the guidelines for making a node implicitly realize instances or not. But I think curve length could work on instances implicitly? It doesn't output them, and I think that's what users would expect anyway.
Member
Followup tasks for the newly legacy nodes:
#91762 (Updated versions of curve to points and curve endpoints nodes)
#91763 (Updated version of subdivision surface node)
#91764 (Updated version of edge split node)
Followup tasks for the newly legacy nodes: #91762 (Updated versions of curve to points and curve endpoints nodes) #91763 (Updated version of subdivision surface node) #91764 (Updated version of edge split node)
Author
Member
2 Participants
Reference: blender/blender#91672
