Keymap priorities are different #91794
Reference: blender/blender#91794
Graphics card: NVIDIA GeForce GTX 1650 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-27 18:29, hash:
c53ffda8a4
Worked: 3.0.0 Alpha, branch: master, commit date: 2021-08-23 15:09, hash:
7d17f2addf
1 ) Keymaps in the same area (3D View), don't prioritize their order above their activation. Specifically, I have a command as {key shift}+{key tab}.
From top down, #1 is
view3d.localview_clickdrag
(Local View), as [Click Drag],view3d.localview
(Local View), as [Click],wm.context_toggle
(Context Toggle), as [Press].Before #3 would not run because #2 would run unless I move the mouse in which case #1 would run (as intended), now #3 will always run no matter what unless I disable it.
2 ) Keymaps from Screen, no longer override keymaps for example from 3D View.
In Screen I have {key shift}+{key Z} for
screen.repeat_last
(Repeat Last), as Press.In 3D View I have {key shift}+{key Z} for
view3d.toggle_shading
(Toggle Shading Type), as Press.Before, Repeat would work, now it only works if I move the mouse outside of the 3D View's area (because no other area has the same key in use)
Added subscriber: @Phigon
Hi, thanks for the report. I think you have customized the Keymap.
Not sure I understand the first part of the report but in 2nd part you have assigned same keys for two different operations, which conflicts with Blender’s default keymap.
Could you please clarify the exact issue? Tested on master &
962153dbed
, both gave me the same output.Yes I'm using custom keys. I use an addon to add keys above Blender's keys.
1
Go to the preferences under 3D View or whatever, and add 2 keys with something unused (like {key u}). Set the first to be Click Drag, and the second to be Click.
Maybe
transform.translate
andobject.select_all
.When you press the button without moving the mouse, the second op will run, and if you drag the mouse first the first will run. You can switch them around if you want.
Next change the / add a key below to be Press. The above key(s) will now never run again, unless the bottom op's poll fails.
2
Go to the preferences, under 3D View, add a key and op {key u} (or pick the key of an existing op).
Under Screen or Window add something, like
ed.undo_history
(which can be used in and out of the 3D View).Only the 3D View's op will run in the 3D View.
Added subscribers: @lichtwerk, @ideasman42, @iss
Here all builds give consistent results: First time keymap for 3D view is used, then keymap for Window is used.
I don't think there is any system in place to resolve keymap conflicts between various areas apart from operator poll functions. Usually this is hardcoded in operators to pass through events if some conditions are not met. Not sure if keymaps are read in order, but I don't think this would be meant to be deterministic.
Not 100% sure on this though, but I don't see code to dispatch duplicate keymaps. @lichtwerk, @ideasman42 Am I correct here?
Sorry, my fault.
I went to record both blender builds, side by side repeating my previous instructions, wherein this time it would not work.
Confused, as I could swear it worked last time, I did some tests and found the problem was my addon's keymapping.
One of the things I do with it is disable Blender keys (and I didn't realize I already specified key conflicts between Click/Drag and Press).
What went wrong was that my addon compared with "is" for bools instead of "==", and before the keymap
bool
shift/ctrl/alt were actual Booleans, and now return anint
.For example
bpy.context.window_manager.keyconfigs.active.keymaps['3D View'].keymap_items['wm.context_toggle'].shift
would returnTrue
, now it returns1
My previous steps possibly worked because of a glitch or I'm just misremembering but either way, I can't repeat the process on video and have got my keys working, so the problem is solved.
