Node Wrangler: Blender freezes when Lazy Connecting geometry nodes #91876
Closed
opened 2021-10-01 14:02:25 +02:00 by Vitor Boschi · 8 comments
Operating system: Linux-5.11.0-34-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.63.01
Broken: version: 3.0.0 Alpha, branch: Master, commit date: 2021-10-01 Unknown, hash: 798e59300280605b8886d9a1f52e1fcf8e5ac008
Blender freezes in a busy loop and eventually gets killed due to OOM after trying to lazy connect geometry nodes. This seems to work most of the time but is always reproducible on the attached blend.
Note: might be related to #91877
  1. Open attached file: lazy-connect-bug.blend
  2. Try to Lazy Connect Curve to Mesh node to Set Position: move the mouse closer to Curve to mesh, then hold Alt+RMB, drags closer to Set position and releases RMB (both nodes should be highlighted red before releasing RMB)
  3. Freeze
**System Information** Operating system: Linux-5.11.0-34-generic-x86_64-with-glibc2.31 64 Bits Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 470.63.01 **Blender Version** Broken: version: 3.0.0 Alpha, branch: Master, commit date: 2021-10-01 Unknown, hash: `798e59300280605b8886d9a1f52e1fcf8e5ac008` **Short description of error** Blender freezes in a busy loop and eventually gets killed due to OOM after trying to lazy connect geometry nodes. This seems to work most of the time but is always reproducible on the attached blend. Note: might be related to #91877 **Exact steps for others to reproduce the error** 1. Open attached file: [lazy-connect-bug.blend](https://archive.blender.org/developer/F10712840/lazy-connect-bug.blend) 2. Try to Lazy Connect Curve to Mesh node to Set Position: move the mouse closer to Curve to mesh, then hold Alt+RMB, drags closer to Set position and releases RMB (both nodes should be highlighted red before releasing RMB) 3. Freeze
Author
Added subscriber: @vitorboschi
Richard Antalik changed title from Blender freezes when Lazy Connecting geometry nodes to Node Wrangler: Blender freezes when Lazy Connecting geometry nodes 2021-10-01 23:55:02 +02:00
Added subscriber: @iss
Changed status from 'Confirmed' to: 'Needs User Info'
Is this still an issue? I was checking again, but I am not able to reproduce the issue anymore. Since issue is reported for alpha, I don't have exact build to check.
Author
I've just tested in 3.2 and master (debug mode) and couldn't reproduce anymore. Guess we can close it.
> In #91876#1377327, @iss wrote: > Is this still an issue? I was checking again, but I am not able to reproduce the issue anymore. Since issue is reported for alpha, I don't have exact build to check. I've just tested in 3.2 and master (debug mode) and couldn't reproduce anymore. Guess we can close it.
Thanks for checking, will close then.
2 Participants
Reference: blender/blender-addons#91876
