"Long Hair" children pulled to world origin when using Texture (2.93.4 regression) #91887
Reference: blender/blender#91887
Graphics card: NVIDIA GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.11
Broken: version: 2.93.4, branch: master, commit date: 2021-08-31 09:23, hash:
b7205031ce
Worked: 2.93.3
My particle hair system works as expected in 2.91+ up to 2.93.3:
In 2.93.4, the children are pulled towards world (not object) origin:
This appears to only happen IF a texture is used to affect Density AND "Long Hair" is checked.
Blend file with error:
Bug3.blend
Added subscriber: @sentharn
Added subscriber: @iss
Can confirm bug in
7ec351c0d5
will try to bisectAdded subscriber: @mont29
Caused by
c2f74d6243
CC @mont29
@iss This cannot be 'caused' by
c2f74d6243
, but only revealed by this commit. Division by zero are never, ever acceptable.Guess someone needs to spend some time in particle code to understand again what and why this is happening.
And also check if this is reproducible in current master as well.
Sorry my bad, I automatically assumed commit broke something. Should have checked that this is actual cause.
Yes it happens in master. I specify LTS only issues if they are critical and happen in LTS only.
The new (correct) behavior in project_v3_v3v3() is causing the issue.
psys_thread_create_path() in source/blender/blenkernel/intern/particle.c has a code path to create child paths. Around line 3017ish it calls project_v3_v3v3(dvec, off2- [x], (key- [x] + k)->vel);
For whatever reason, (key- [x] + k)->vel is a zero v3.
I don't know anything about the particle code (except how to misuse it) but I hope this helps track down the issue!
EDIT: 3017, not 3070
@iss the problem is still present in today's 3.1 Alpha build and 3.0 release. Should it be tagged as a 3.1 problem?
I think I have tagged this because it was regression in 2.93, but AFAIK these tags are supposed to signify when it should be fixed, so will remove the tag. Regression in LTS is clearly visible in broken/worked fields.
Added subscriber: @dfelinto
Thanks for the report. Marking this as known issue since it depends on the old particle settings which is end of life .
