Cursor size for "Use Cursor for Depth" in Sculpt doesn't reset properly on undo #91963
Reference: blender/blender#91963
Operating system: MacOS 11.6
Graphics card: Radeon RX 580 8 GB
Broken: 2.93.4 (2.93.4 2021-09-01)
Broken: 2.93.5 (2.93.5 2021-10-05)
Broken: 3.0.0 (3.0.0 2021-10-05)
Worked: don't know
Cursor size for "Use Cursor for Depth" (Sculpt -> Box/Lasso Trim -> Trim Mode: Join) doesn't reset properly on undo.
Based on the default startup
File -> New -> Sculpting
Select Box Trim (or Lasso Trim)
In tool options, select Trim Mode: Join
In tool options, select Use Cursor for Depth
Use tool on the outside of the object (Note that the geometry created has a volume)
Undo (if you used the tool more times, repeat the undo each time).
Use the tool again.
Expected result:
Tool works normally after all undo.
Actual result:
After undoing all tool uses, the tool disregards the cursor size and the next shape created is flat/collapsed.
Additional notes:
It only happens when the file starts in Sculpt mode (hence the New -> Sculpting). If started in Object mode, and then switched to Sculpt, it is not occurring.
After switching tools (even without actually using another tool), it seems to work correctly.
Also if switched from Sculpt to Object mode and back, it's working properly. Unless you undo from before switching to the Object mode, and undo all the tool uses, it happens again.
Added subscriber: @rednaxel
Added subscriber: @mano-wii
Thanks for the report,
I can confirm, but I had to do some steps a little different from the ones described.
So I'll edit the description if you don't mind ;)
