Linked Instances Across Scenes have unreliable updates when editing their common mesh data. #91996
Reference: blender/blender#91996
Broken: 2.93.4 LTS;
Broken: master
With two different objects in two different scenes sharing a same obdata Mesh, editing the mesh in one of the scene can fail to properly update object in the other scene.
Switch to edit mode and back, now the cube is shown with expected first material slot (red) as well.
NOTE: If you replace step 4 by a mesh geometry editing (e.g. rotate the mesh in Edit mode), in current master there is the same missing update issue in Scene 1, but in 2.93LTS it is properly updated... Regression introduced by
51568030e9
.Example.blend
Original report
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 680/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash:
84da05a8b8
If you link an instanced object to another scene, having it's material link to object, it can have a different material from the non-instance. However upon saving and re-opening the scene, the instance's material will revert to that of the non-instance.
Example.blend
Added subscriber: @Bobo_The_Imp
Added subscriber: @mano-wii
Thanks for the report, I can confirm the problem.
I believe the #core module handles Read/Write .blend files (Am I right?), so tagging it.
Added subscriber: @mont29
There is no write/load bug here, 'assigning a material in edit mode' means you assign the active material index (i.e. material slot) to the selected faces of the mesh. This will affect both objects, since they share the same mesh, assigning faces of that mesh to material slot 1 in one object will make it use material of material slot 1 in the other object as well.
The issue here is that object in scene 1 is not immediately updated (it is as soon as e.g. you switch to edit mode and back). Same goes if you edit mesh shape in Scene 2, go back to Object mode and switch to scene 1, you also need to force update to see the changes... Not sure what is happening here, it only happens in some specific order (e.g.if you change material slot assignment on mesh in scene 1, it is immediately updated in scene 2 as well).
Linked Instances Across Scenes with Material Link Set to Object do not Retain Material Assignment Through Savesto Linked Instances Across Scenes have unreliable updates when editing their common mesh data.Changed status from 'Needs Triage' to: 'Confirmed'
Oh I see!
The step "Set both materials to Object Link in the material properties" baffled my mind.
(I forgot to confirm)
Added subscriber: @ideasman42
Mesh editing regression comes from
51568030e9
(tagging @ideasman42 here too).
