Library Override not working on Linked materials #92081
Reference: blender/blender#92081
Blender Version: 2.93.1
Short description
Changing the custom property value won't update the shader after the Library Override.
Steps to Reproduce
Pose Mode
Texture
from {nav Bone Properties > Custom Properties > Texture}I recorded a small video to show it
https://youtu.be/p99P2kJN5xQ
CUBE-RIG.blend
Added subscriber: @Sergey-Belyaev
forgot to mention that I am using 2.93.1 version of Blender
Added subscriber: @mano-wii
Thanks for the report, but could you describe the steps to reproduce the bug in even more detail?
The report mentions
"linking the rig to another file"
but when I do that, only the rig is linked. The object with the material does not appear.It also reminds me of #76093 (bone visibility driven by custom property not working with library override)
Sure no problem:
Go to file-Link
navigate to the cube file and then to collection. select collection to link
Then Object-Relations-Make Library Override-Make library override
now select the cube and you will see his material and the nodes, you can pin it
select armature and go to pose mode
select property bone and try changing the value
when the value is changed the value iun the shader does not updates
However if you just open the rig file and try changing the property bone value it will work and the driver is updating
This issue only appears in
blender-v2.93-release
branch (3.0.0 seems fine)Hovering over the
Value
node says:Can't edit this property from a linked data-block
so probably the current behavior is expected.@mano-wii , can you please check this?
Changed status from 'Needs User Info' to: 'Needs Developer To Reproduce'
Added subscriber: @mont29
Nice to see this looks already resolved in 3.0.0.
I suspect that's why the fix wasn't backported? @mont29, could you shed some light on this?
Some consistency improvements/bugfixes were made in 3.0, that won't be backported to 2.93, yes. But in general override workflow of materials remains considered as experimental at best, it still needs time and attention to fix some key issues there. See milestone 6 of #73318 (Library overrides).
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
