"Setup Tracking scene" not alligned when using vertical Videos #92287
Reference: blender/blender#92287
Graphics card: NVIDIA GeForce GTX 1650/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-09-29 22:05, hash:
84dcf12ceb
Worked: not sure
Noticed that all vertical videos(horizontal video with frames extracted with -90 offset) I tracked using the smartphone and dslr source were not alligned with the tracking marker empties when "Setup Tracking scene" was done
when used horizontally it works perfect but difficult to interact with blender sideways
rendered video rotated on export: https://twitter.com/v6_prime/status/1447977113303220226?s=20
Added subscriber: @V-prime
Added subscriber: @lichtwerk
Hi and thx for the report.
To speed things up, please attach the (already rotated) source movie and the corresponding .blend file (with tracking, prior to
setup tracking scene
).the frame sizes were too high so i just put 12 frames + the original blend file with 'setup tracking scene' ready to be pressed
track test 12 frames.zip
SourceVideo15sec.zip
Hm, not totally sure if this is a bug (but I also cannot make it work).
No expert in tracking here, so afraid I'll have to pass this on to someone else with more knowledge.
I've tried different camera presets (since camera sensor of course makes a difference), but pretty sure this is not the source of the problem.
Just dropping the ffmpeg info on the file (it contains the
rotate
property), but pretty sure this is not the source of the problem either.Could it be that basing the focal length on the width (always) is not correct?
https://developer.blender.org/diffusion/B/browse/master/source/blender/blenkernel/intern/movieclip.c$1014
(but this is also a stab in the dark without checking further)
Added subscriber: @KNAO
This problem occurs because the "Sensor Fit" of the camera property in the 3D scene is switched to "Auto" when the "Solve Camera Mostion" is executed.
In the case of Vertical Videos, the Movie clip editor specifies the short edge value as the Sensor Width, but when the "Solve Camera Mostion" is executed, the "Sensor Fit” is set to "Auto," and the height of the long side is set to the value specified in the movie clip editor based on the aspect ratio of the image.
As a result, the sensor values of the camera sensors in the 3D scene are not correct and the result will not be reflected correctly.
Currently, the problem can be solved by switching "Sensor Fit" to "Horizontal". However, when "Solve Camera Mostion" is executed, it will switch to "Auto" again.
Ideally, when the "Solve Camera Motion" is executed, the "Sensor Fit" of the 3D scene camera is switched to "Horizontal", and the "Height" value is automatically calculated from the image resolution ratio.
If the height value is automatically calculated, troubles are less likely to occur when exporting to external software.
Added subscriber: @badbunny_uk
