Toggling "Visible in Render" is extremely slow since 2.90 (when texture is used in modifier) #92386
Reference: blender/blender#92386
Graphics card: GeForce GTX 1660/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.93.5, branch: master, commit date: 2021-10-05 12:04, hash:
a791bdabd0
Broken: version: 2.90.0
Worked: 2.83.18.0
Caused by
23919d2275
btw.So this might be an intended change in the end (with no real way around), will let developers decide here.
Toggling an object's visibility for rendering is very slow (>10s freeze in the attached file, on my system) in 2.93 LTS, but is instant in 2.83 LTS.
Toggling viewport visibility is instant in both versions.
In the attached file, simply toggle any object's render visibility in the outliner. At least on my system, Blender freezes for around 10 seconds each time you do this in this file, and >30 seconds on some of my other files (which I can't share unfortunately).
I realise these are quite hi-poly objects but they have never been a problem in previous Blender versions.
Blender Slow Hide Test - Packed.blend
Added subscriber: @Don-Macaron
Added subscriber: @mano-wii
I cannot reproduce this with either the latest stable or current development versions of Blender.
It's pretty fast here. Almost instantaneous.
Please try the latest daily build: https://builder.blender.org/download/
Go to File → Defaults → Load Factory Settings and then load your file to see if you still can reproduce this issue.
If the problem persists, please give us more clear instructions on how to reproduce it from scratch.
Hi, thanks for investigating.
I've tried the latest 2.93 build, and have tried loading Factory Settings both on that version and on the LTS 2.93 version.
The problem does still persist, and still does not happen in 2.83.
I'm getting a colleague to try the file on his PC and will report back on that.
However, I have noticed that removing the texture in the Displace modifier from all the objects seems to solve the issue (even though the Displace modifier was not enabled in viewport or render.)
I didn't pack all the textures into the previous .blend file I uploaded here, so perhaps the fact that the texture was missing when you tried it might have had an effect?
Here is a version with the textures packed:
I'm not yet sure how to reproduce the error fully from scratch, all I know is that most of my files exhibit this behaviour.
It's quite possible.
I'll take a look at the new version soon.
I opened the file in 2.83 and 2.93 but didn't notice any difference in duration when hiding and unhiding the objects.
Perhaps you are experiencing an issue described in #73199 (Editing an object that is referenced in a disabled modifier (of another object) forces the other modifiers on the same stack to update).
But the ">10s freeze" is really not expected.
Can you try the latest daily build (3.0)? https://builder.blender.org/download/
Okay, so interesting result: the latest 3.0 build is absolutely fine. Render visibility for all parts can be toggled instantaneously.
The plot thickens...
I've re-tried in the 2.83 & 2.93 latest builds and latest LTS versions (just to double check) and it definitely seems to be an issue with the 2.93 versions specifically.
It seems the wait time can vary a bit (maybe depending on how many other programs I have running?) but it's generally in the range of 5-12 seconds. It's also impossible to click & drag to hide multiple objects at once, so I have to do them one at a time, and wait 5-12 seconds per object I want to hide.
Also, just to note, my colleague has now tried the file on his PC and has the same result as me - 2.83 works fine but 2.93 freezes
I've tested it on 2.93.2, 2.93.5 and 2.93.6, but I still can't replicate the problem.
Tested on Windows and on Mac.
I'll leave the report open in case anyone else can take a look.
But it seems to be a low priority problem, while this is a real issue, it is only happening to a few people so far. And it seems that to troubleshoot it, developers needs to have direct access to hardware.
Added subscriber: @lichtwerk
I can confirm the slowness of the toggle.
Cant confirm this, for me 3.0, 3.1 and 3.2 are equally slow, @Don-Macaron: could you recheck?
Will try to see where this changed between 2.83 and onwards
Changed status from 'Confirmed' to: 'Needs Developer To Reproduce'
Caused by
23919d2275
Toggling "Visible in Render" is extremely slow in latest 2.93 LTSto Toggling "Visible in Render" is extremely slow since 2.90 (when texture is used in modifier)Just noticed we have a report for this already, see #83271 (Displace modifier with Image Texture causes scene slowdown), will merge reports
Closed as duplicate of #83271
