Grease Pencil Arrange Stroke operator does not function with Curve Editing #92417
Reference: blender/blender#92417
Operating system: Linux 64-bit
Graphics card: GTX 1080 ti
2.93.5 and 3.0.0 alpha
In edit mode, "Arrange Stroke" operator does not work when use_curve_edit is enabled.
GP_arrange_bug.blend
Disable Curve Editing and try again to see that it otherwise works as intended
Added subscriber: @rocketman
Added subscribers: @filedescriptor, @antoniov
Opening your file and testing does not work, but If I select the stroke and use Arrange works.
@filedescriptor could you test?
@filedescriptor It looks some type of wrong selection flags.
Try this:
Disable bezier mode.
Select stroke
Enable bezier mode->Stroke is still selected.
Try arrange->Does not work
Select again the selected stroke (the stroke was already selected)
Try arrange->works
I notice this as well, @antoniov but the odd thing is that the issue seems to re-emerge unpredictably for many kinds of per-stroke operators.
For instance, Delete > Stroke will, at times, not work either, as if the stroke isn't selected when it is. The trouble is that it is common enough to be irritating yet I can't seem to reproduce it reliably!
@rocketman Do you have the problem when working with Beziers mainly (or switch to Beziers)?
Yes the problem seems limited to Beziers.
Another issue I'm noticing is that it affects sculpt mode selection masking. The selected stroke is not editable in sculpt mode, but other unselected strokes are. Should I put that in a separate report?
@filedescriptor I guess the problem is the conversion from Stroke to Bezier is loosing the previous selection. What do you think?
@rocketman I think the sculpt is the same problem, so don't open a new report. If in the future we see is a different issue, we can open the report then.
