Erratic pen pressure #92436
Reference: blender/blender#92436
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-10-22 22:32, hash:
231d66d8ba
Worked: 2.93.4
Tablet pen pressure is erratic in both sculpting and grease pencil. occasionally pressure seems to be 100%
using xp-pen star 06, windows ink turned off in tablet settings. changing tablet API in blender doesn't help.
This doesn't happen in krita or in Blender 2.93.4.
OR:
Added subscriber: @jasonklee
Added subscribers: @PrototypeNM1, @iss
@jasonklee can you provide screenshot/recording of how this issue exhibits?
@PrototypeNM1 does this ring a bell?
Is pen pressure 100% for the full stroke when this happens, or just part of it? A screenshot of the issue would help narrow down the problem.
it's the full stroke. here is a video of the problem. the first 3 strokes are affected, then it works normally for a while then it happens several more times. https://www.youtube.com/watch?v=_EKENK46o-0
Thanks for the video. The cause of this issue relates to #89341 (fixing it will hide the problem).
I'll need to put together some tests to better understand what your tablet is doing.
You're welcome. Just to clarify, my tablet is not in mouse mode as I think #89341 would suggest. Also, I've discovered that when I use "Windows Ink" in my tablet driver, the problem seems to be gone, but windows ink introduces other problems system wide. Hopefully this helps you somehow.
Thanks for clarifying, it was more a note to self as I know the code causing the problem. :)
The symptoms of this issue should be resolved by
60c0b79256
, but there remains an underlying issue that needs further investigation. Lack of pen pressure was an indicator that Wintab was falling back to low frequency input, which can result in jagged lines when drawing.Changed status from 'Needs User Info' to: 'Confirmed'
@jasonklee could you repeat the bug by running
blender.exe --debug-wintab
with this build, copy the system console to this link, and link the paste in a reply to this report?Just a note: this bug report doesn't happen in the main release of Blender because of fallback that is hiding it. We'd still like to fix this properly because the fallback causes jagged lines when drawing.
Changed status from 'Confirmed' to: 'Needs User Info'
https://developer.blender.org/P2946
Hope it helps.
here is another without loading previous preferences just in case.
https://developer.blender.org/P2947
@jasonklee Could you try this build, and if things are still broken then same instructions as before for getting the log.
Note for self: this build tests if using PK_CHANGED filters invalid data.
@jasonklee quick ping if you're still available to test the prior build; heads up that we normally close tasks that go without reply for a week.
