Cycles HIP device missing driver version check #93109
10 Participants
Reference: blender/blender#93109
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: AMD Radeon RX 5700 XT ATI Technologies Inc. 4.5.14742 Core Profile Context 21.8.2 27.20.22025.1006
Broken: version: 3.1.0 Alpha, branch: master, commit date: 2021-11-14 00:26, hash:
7e82c840b7
Worked: Unknown
When using the new HIP GPU rendering with cycles I currently get this error (using the graphics card listed above):
Just tried to render the default cube, setting engine to
and device toGPU Compute
.Logs:
blender_debug_output.txt
blender_system_info.txt
Added subscriber: @brunnerh
Added subscriber: @deadpin
Are you using the very latest AMD driver - it seems your driver version is a little older? https://www.amd.com/en/support/kb/release-notes/rn-rad-win-21-40-beta-blender-3-0
Added subscribers: @leesonw, @BrianSavery, @brecht
I thought that older AMD drivers don't even have the HIP library, so there would be no need to check the driver version, since there exists no older HIP driver.
However I think 21.8.2 is an Adrenalin driver from August so I'm not sure what is going on. Maybe we do need that driver version check?
CC @BrianSavery @leesonw.
Yes I think we do need to check unfortunately.
Ok, I'll consider this a confirm to be fixed for 3.0 then.
It should be pretty simple to add a check using
hipDriverGetVersion
I guess.I'll make that fix right now.
I did an automatic driver update to v21.10.2 (as my card is not listed as supported for the drivers you linked) and rendering the default cube and some other scenes worked.
However, one of my complex scenes lead to this error:
I then tried installing the linked beta driver, but the error remained.
Should I try to track down what element is causing the error or is my GPU simply not really supported?
I was curious and tried to find the source, it looks like the issue is a little texture I made that has the dimensions 32,768 px x 864 px
book.blend
Perhaps that exceeds current hardware capability. Per your system info file:
With OpenCL we did our own texture filtering, with CUDA and HIP we use the textures and so are also limited by them.
With CUDA on a RTX A6000 I see this:
I'm not sure if 16384 is an AMD hardware limitaton or if HIP is being too conservative?
Actually, it turns out
hipDriverGetVersion
does not give the info we need. we'd have to do something here like looking up the driver version in the registry.Incidentally 16384 is exactly half the size of the texture, so I tried scaling by 0.5 but it still error'd.
(Could there be an off-by-one error here that rejects the texture even though it should work in my case?).
After scaling by 0.5 again to 8192 x 216 it started working.
Added subscriber: @Jeroen-Bakker
Max texture size should not be seen as an exact number. It depends on type of texture and other attributes. If I recall correctly most textured allocations work from 12k and lower.
I added the texture size issue to #91571. We should at a minimum give an error to the user, but could also resize since we already have code for that.
Invalid value error for HIP device renderingto Cycles HIP device missing driver version checkAdded subscriber: @ThomasDinges
@BrianSavery Would
hipRuntimeGetVersion
give relevant info? https://rocm-developer-tools.github.io/HIP/group__Driver.html#gae8b7ba34d2e11e334650aa51a4dd87eeAdded subscriber: @Sayak-Biswas
@BrianSavery, @Sayak-Biswas, is there any update on this from your side? We really like to have all high priority bugs fixed at least a week before the release, which means by next Wednesday.
We could probably figure out an appropriate driver check ourselves, but would like to know as soon as possible then if this is something we should work on.
doesn't really provide the correct info. We can get the relevant driver version string from the Windows registry. I will add this to give out an error in case the driver < 21.40.Added subscriber: @LazyDodo
Is there any chance we can trust the version info of the shared
amdhip64.dll
file? i'd rather query that than go rummage around in the registry, should be pretty straight forward, example inbli_windows_get_module_version
We should be able to use it, I am confirming with the driver packaging team. The drawback would be that this dll version info will not the same number as the Radeon Software package version (i.e not 21.40 etc) so we won't be able to provide a more user friendly message other than maybe "Please upgrade driver to 21.40 or later".
That's already the only message we provide to users in the preferences. We don't use the detected driver version number in the message to users, only the debug logs have more detail. So it doesn't really matter.
Submitted patch checking for file version of amdhip64.dll
Added subscriber: @2905710881
Is there any built-in hip support in 21.Q3.1? Is there a chance for future Adrenalin to join as well?
You need the 21.40 driver. HIP will come to the Adrenalin driver in the future, see https://devtalk.blender.org/t/2021-11-9-blender-rendering-meeting/21326/14
Please don't use this tracker for user questions though!
This issue was referenced by blender/cycles@8f81c6dfd8
3bb8d173e7
