Geometry Nodes > Alembic Velocity #93266
Reference: blender/blender#93266
Operating system: macOS-10.15.7-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 580X OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.10.19
Broken: version: 3.0.0 Beta, branch: master, commit date: 2021-11-20 16:50, hash:
1b2ee3cf20
Worked:
Geometry Nodes can't access Velocity attribute of Alembic file exported from 2.93 or newer..
Exported .abc file containing velocity attribute and Imported back to blender works for motion blur rendering, but I can't access it for Geometry Nodes 3.0, 3.1 ... (fields). I can't confirm it is happening also for 2.93 GN because I never get familiar with previous Attribute system (thanks God for fields :) ).
File contains collection with original Cube used for export to Alembic ...
test_ABC_Velocity.blend
... and second collection with Imported this .abc file.
test_ABC_Velocity.abc
... but Velocity attribute is not listed.
What works for me is [this test file ]] from [ https:*developer.blender.org/D2388 | this diff page ... velocity listed.
Does it can be somehow related to Brecht's work on a new velocity attributes system? Thank you
Added subscriber: @FilipMond
Added subscribers: @kevindietrich, @dr.sybren, @brecht, @lichtwerk
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
This is because the alembic file you are posting does not have .velocities:
The file from D2388 in contrast has velocities:
So the question here is when velocities are exported to alembic?
This could be beneficial to have as an attribute (as usage in Geometry nodes), maybe we could [optionally] write them to alembic on export?
In any case, this is not a bug, just asking @dr.sybren, @brecht, @kevindietrich if having an option to force velocities (at least for deforming modifiers also -- or also when having geometry node modifiers as input) on alembic export is something we should look at? As an alternative, one might think of having some sort of
Time
input node (that would enable us to read e.g. positions on previous frames) -- but I think this is even more of a hassle to get right?Think this could be closed, but leaving open for an opinion here still.
If a velocity attribute should be exported to Alembic then it should be generated by the modifier stack (including geometry nodes of course), or by some other means in Blender. The Alembic exporter should not concern itself with generating such an attribute.
In Blender we only write a velocity attribute in cases where the velocity can't be determined automatically due to changing topology. That's partially because velocity does not give you multi-step motion blur, so it's less accurate.
An option to force writing velocities in Alembic may be useful in some cases, but I'm not sure it's really the correct or standard workflow. Alembic files can contain a sequence of frames / time samples, and if there is a simple correspondence between them there is no need for a velocity attribute. The case where you write a velocity attribute is when that is not possible, typically a physics simulation with changing topology where you get the velocity from the simulation.
Implementing this is in Alembic export is not simple, and also redundant if the Alembic file already contains multiple time samples. If anything I would think of an option to derive velocities from time samples in an Alembic file on import.
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
Thx for the input!
Will close then...
So ... any hint how to orient instances based on velocity direction (or previous/next vertex position)?
Like was asked here ... I will change my Answer according to this conclusion ... or does this have any other than it is not a bug? Thank you.
You want to compute a velocity attribute from an Alembic file that does not already have it. Support for that as part of Alembic import is a feature request.
There may be some workaround. Perhaps loading the same object a second time with a frame offset of 1, doing an attribute transfer and computing the difference in positions.
@brecht "Workaround" seems to be working ... https://blender.stackexchange.com/a/244606/2214 ... in hope of better way in a future :) Thanks
BTW ... if I understood you right, Alembic should store velocity for fluids ... can you confirm that?
Because I don't see any listed as seen in original post ... also no effect under shader Atribute node when written manually. If does it work for you -any link How to access velocity properly? Thank you
