Hotkeys conflict between Shader Nodes, Compositing Nodes, GeoNodes and Texture Node Editor. #93403
Open
opened 2021-11-26 12:30:42 +01:00 by Oxicid · 18 comments
Operating system: Windows-10-10.0.17763-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.68
Broken: version: 2.93.6, branch: master, commit date: 2021-11-16 14:54, hash: c842a90e2f
I have hotkeys on frequently used nodes in shader editor. When I switch to Compositing, first of all I have hotkeys already assigned to similar nodes (I did it in shader editor, but they are automatically assigned in compositing). Secondly, I get an error in Compositing - Not a shader or geometry node tree.
  1. Apply the "I" button to the "Invert" node in the shader editor
  2. Switch to Compositing or Texture Node Editor
  3. Call the invert node with the I button
You get the following error
Python: Traceback (most recent call last):
File "D:\BF_daily_build\2.93.0\blender-2.93.7-candidate+v293.4ec6cc412d7f-windows.amd64-release\2.93\scripts\startup\bl_operators\node.py", line 138, in invoke
  result = self.execute(context)
File "D:\BF_daily_build\2.93.0\blender-2.93.7-candidate+v293.4ec6cc412d7f-windows.amd64-release\2.93\scripts\startup\bl_operators\node.py", line 129, in execute
  self.create_node(context)
File "D:\BF_daily_build\2.93.0\blender-2.93.7-candidate+v293.4ec6cc412d7f-windows.amd64-release\2.93\scripts\startup\bl_operators\node.py", line 92, in create_node
  node = tree.nodes.new(type=node_type)
RuntimeError: Error: Cannot add node of type ShaderNodeInvert to node tree 'Geometry Nodes'
Not a shader node tree
https://archive.blender.org/developer/file/12282/12282119/bandicam_2021-11-26_16-53-56-020.mp4
https://archive.blender.org/developer/file/12271/12271877/Node_Conflict.blend
**System Information** Operating system: Windows-10-10.0.17763-SP0 64 Bits Graphics card: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 471.68 **Blender Version** Broken: version: 2.93.6, branch: master, commit date: 2021-11-16 14:54, hash: `c842a90e2f` Worked: (newest version of Blender that worked as expected) **Short description of error** I have hotkeys on frequently used nodes in shader editor. When I switch to Compositing, first of all I have hotkeys already assigned to similar nodes (I did it in shader editor, but they are automatically assigned in compositing). Secondly, I get an error in Compositing - Not a shader or geometry node tree. **Exact steps for others to reproduce the error** 1) Apply the "I" button to the "Invert" node in the shader editor 2) Switch to Compositing or Texture Node Editor 3) Call the invert node with the I button You get the following error ``` Python: Traceback (most recent call last): File "D:\BF_daily_build\2.93.0\blender-2.93.7-candidate+v293.4ec6cc412d7f-windows.amd64-release\2.93\scripts\startup\bl_operators\node.py", line 138, in invoke result = self.execute(context) File "D:\BF_daily_build\2.93.0\blender-2.93.7-candidate+v293.4ec6cc412d7f-windows.amd64-release\2.93\scripts\startup\bl_operators\node.py", line 129, in execute self.create_node(context) File "D:\BF_daily_build\2.93.0\blender-2.93.7-candidate+v293.4ec6cc412d7f-windows.amd64-release\2.93\scripts\startup\bl_operators\node.py", line 92, in create_node node = tree.nodes.new(type=node_type) RuntimeError: Error: Cannot add node of type ShaderNodeInvert to node tree 'Geometry Nodes' Not a shader node tree location: <unknown location>:-1 ``` https://archive.blender.org/developer/file/12282/12282119/bandicam_2021-11-26_16-53-56-020.mp4 https://archive.blender.org/developer/file/12271/12271877/Node_Conflict.blend
Author
Added subscriber: @Oxicid
Oxicid changed title from Hotkeys conflict between Shader Nodes, Compositing Nodes and Texture Node Editor. to Hotkeys conflict between Shader Nodes, Compositing Nodes, GeoNodes and Texture Node Editor. 2021-11-26 12:31:55 +01:00
Author
The following categories should be added to the hotkeys settings, to avoid conflicts between hotkeys image.png
The following categories should be added to the hotkeys settings, to avoid conflicts between hotkeys ![image.png](https://archive.blender.org/developer/F12271978/image.png)
Member
Member
Member
Hi, thanks for the report. I am not able to reproduce this on master and 2.93.7 (4ec6cc412d7f)
To reproduce the error. Could you please provide exact reproducing steps? I manually changed the shortcut. Not sure if I understand the use of py script.
Can you reproduce this issue with factory settings?: {nav File > Defaults > Load Factory Settings}
Hi, thanks for the report. I am not able to reproduce this on master and 2.93.7 (`4ec6cc412d7f`) To reproduce the error. Could you please provide exact reproducing steps? I manually changed the shortcut. Not sure if I understand the use of py script. Can you reproduce this issue with factory settings?: {nav File > Defaults > Load Factory Settings}
Author
In #93403#1260503, @PratikPB2123
bandicam 2021-11-26 16-53-56-020.mp4
{nav Shading > Ctrl+A > Color > Invert > right mouse button > Assign Shortcut > I}
Now everything will work fine in the shading mode, but in other node editors, when you press "I" you will get an error.
PS. And the .py file is not a script, but saved hotkeys
> In #93403#1260503, @PratikPB2123 [bandicam 2021-11-26 16-53-56-020.mp4](https://archive.blender.org/developer/F12282119/bandicam_2021-11-26_16-53-56-020.mp4) {nav Shading > Ctrl+A > Color > Invert > right mouse button > Assign Shortcut > I} Now everything will work fine in the shading mode, but in other node editors, when you press "I" you will get an error. PS. And the .py file is not a script, but saved hotkeys
Member
Member
Hi, thanks for clarifying. Can confirm now :)
Agree that each of the node editors should have their own set of shortcuts, even if it means duplicating the shortcuts for the nodes that do work across different editors.
Philipp Oeser removed the
label 2023-02-10 09:22:42 +01:00
i am not able to reproduce the issue , has this been patched already ?
@ravikul-rao I believe contributions to this are still welcome. If you get a chance to work on this remember to refer to this issue, so people following it can help with testing.
Hello! Is anyone working on the problem? I would take it upon myself to solve it.
Hi! I have a solution to the problem, but it seems a bit ugly to me. How can we discuss the code?
Member
@arevkov hi, if you've a PR ready then feel free to submit it: https://wiki.blender.org/wiki/Tools/Pull_Requests
Discussion can happen there.
@arevkov hi, if you've a PR ready then feel free to submit it: https://wiki.blender.org/wiki/Tools/Pull_Requests Discussion can happen there.
Is the task relevant?
Contributor
Guys, please don't. It's already borderline impossible to maintain any other than default keymap and this pushes it beyond point. The amount of keymap entries for node editor is already insane, and quadrupling it is beyond insanity. What Blender gravely needs is unification of shortcuts, not going in opposite direction.
@dfelinto I am honestly curious here. What made you conclude that instead of a simple check whether node can be added in given node editor context, the best course of actions would be to add 246 new keymap entries? (Default keymap has currently 82 entries for node editor). I can't imagine you've considered how difficult it already is to make a custom keymap for Blender, and this change would quadruple that difficulty for node editor section.
Especially given that what changes between node editor modes are just the nodes. Here's a very obscure use case of someone having hotkeyed specific nodes. The solution to such obscure use case should not have devastating effect on keymap customization. I really want to know your thought process here.
Guys, please don't. It's already borderline impossible to maintain any other than default keymap and this pushes it beyond point. The amount of keymap entries for node editor is already insane, and quadrupling it is beyond insanity. What Blender gravely needs is unification of shortcuts, not going in opposite direction. > Agree that each of the node editors should have their own set of shortcuts, even if it means duplicating the shortcuts for the nodes that do work across different editors. @dfelinto I am honestly curious here. What made you conclude that instead of a simple check whether node can be added in given node editor context, the best course of actions would be to add 246 new keymap entries? (Default keymap has currently 82 entries for node editor). I can't imagine you've considered how difficult it already is to make a custom keymap for Blender, and this change would quadruple that difficulty for node editor section. Especially given that what changes between node editor modes are just the nodes. Here's a very obscure use case of someone having hotkeyed specific nodes. The solution to such obscure use case should not have devastating effect on keymap customization. I really want to know your thought process here.
Author
@Rawalanche In some ways you are right, perhaps we should leave the global keys in place, and only have custom hotkeys displayed in separate tabs.
Now the solution is to write a script yourself, so that it adds this or that node by context.
@Rawalanche In some ways you are right, perhaps we should leave the global keys in place, and only have custom hotkeys displayed in separate tabs. Now the solution is to write a script yourself, so that it adds this or that node by context.
Existing keymap entries would not be duplicated but stay in a common node editor keymap. There would be additional, initially empty keymaps for custom shortcuts per node type. But that still has design challenges for user keymap editing, as I mentioned in the PR.
> @dfelinto I am honestly curious here. What made you conclude that instead of a simple check whether node can be added in given node editor context, the best course of actions would be to add 246 new keymap entries? Existing keymap entries would not be duplicated but stay in a common node editor keymap. There would be additional, initially empty keymaps for custom shortcuts per node type. But that still has design challenges for user keymap editing, as I mentioned in the PR.
7 Participants
Reference: blender/blender#93403
