Snap performance regression at high poll rate #93408
Closed
opened 2021-11-26 16:06:40 +01:00 by melak47 · 10 comments
Operating system: Windows-10-10.0.22000-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.76
Broken: version: 3.0.0 Release Candidate, branch: master, commit date: 2021-11-25 17:24, hash: 2fb8c6805a (still broken in 3.1 7b5a6f452a).
Worked: 2.93.4 release
When using a mouse with a high poll rate, blender 3.0 can't seem to keep up with
mouse movements when snapping is on.
Even just 250Hz instead of 125Hz grinds the snapping to a halt in a trivial scene,
making it almost unusable unless you move the mouse veryslowly.
Example scene created in blender with factory defaults, with two cubes and snapping
set to "face" and "center":
repro.blend
Using a mouse with a polling rate higher than 125Hz (many gaming mice go up to 1000Hz):
  1. Select the smaller cube,
  2. press g,
  3. hold ctrl for snapping,
  4. drag the smaller cube over the large cube.
    Observe the snapped location updating less and less often the faster you drag:
    pTazSmLAXx.mp4
Compare with blender 2.93 which doesn't seem to have a problem even at 1000Hz:
GskIXNAhU4.mp4
Workarounds
  • don't use a gaming mouse ( the extra buttons are nice for blender, though :| )
  • change the polling rate in the mouse's accompanying software if possible
**System Information** Operating system: Windows-10-10.0.22000-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.76 **Blender Version** Broken: version: 3.0.0 Release Candidate, branch: master, commit date: 2021-11-25 17:24, hash: `2fb8c6805a` (still broken in 3.1 7b5a6f452aa5). Worked: 2.93.4 release **Short description of error** When using a mouse with a high poll rate, blender 3.0 can't seem to keep up with mouse movements when snapping is on. Even just 250Hz instead of 125Hz grinds the snapping to a halt in a trivial scene, making it almost unusable unless you move the mouse *very*slowly. **Exact steps for others to reproduce the error** Example scene created in blender with factory defaults, with two cubes and snapping set to "face" and "center": [repro.blend](https://archive.blender.org/developer/F12289627/repro.blend) Using a mouse with a polling rate higher than 125Hz (many gaming mice go up to 1000Hz): 1. Select the smaller cube, 2. press g, 3. hold ctrl for snapping, 4. drag the smaller cube over the large cube. Observe the snapped location updating less and less often the faster you drag: [pTazSmLAXx.mp4](https://archive.blender.org/developer/F12289266/pTazSmLAXx.mp4) Compare with blender 2.93 which doesn't seem to have a problem even at 1000Hz: [GskIXNAhU4.mp4](https://archive.blender.org/developer/F12290122/GskIXNAhU4.mp4) **Workarounds** - don't use a gaming mouse ( the extra buttons are nice for blender, though :| ) - change the polling rate in the mouse's accompanying software if possible
Author
Added subscriber: @melak47
Added subscriber: @Wovchick
Added subscriber: @mano-wii
As far as I know, the snapping part of the transform code hasn't gone through changes that would justify this lag. This must be a collateral effect of changes in another area.
Does the problem only appear when you press Ctrl? What happens if snapping is already enabled in the scene? And what happens if you change the shortcut to a key other than Ctrl?
As far as I know, the snapping part of the transform code hasn't gone through changes that would justify this lag. This must be a collateral effect of changes in another area. Does the problem only appear when you press Ctrl? What happens if snapping is already enabled in the scene? And what happens if you change the shortcut to a key other than Ctrl?
Author
If I enable snapping in the menu header, it behaves the same without holding control.
Using the transform gizmo tool with snapping on instead of pressing g, too.
> In #93408#1266235, @mano-wii wrote: > As far as I know, the snapping part of the transform code hasn't gone through changes that would justify this lag. This must be a collateral effect of changes in another area. > > Does the problem only appear when you press Ctrl? What happens if snapping is already enabled in the scene? If I enable snapping in the menu header, it behaves the same without holding control. Using the transform gizmo tool with snapping on instead of pressing `g`, too. > And what happens if you change the shortcut to a key other than Ctrl?
Germano Cavalcante self-assigned this 2021-12-22 20:06:53 +01:00
I can confirm on a mouse with a polling rate of 500Hz
fba9cd019f is the first bad commit
I can confirm on a mouse with a polling rate of 500Hz fba9cd019f is the first bad commit
This issue was referenced by b2e15cb19d
This issue was referenced by b2e15cb19daba51d82191e446b705d11a0ec96fd
This issue was referenced by 586e2face6
This issue was referenced by 586e2face61c2c05b46ccf13889e2153faba0078
Reference: blender/blender#93408
