(Again) makesdna crashes during the build with LTO on s390x architecture (Linux) : #93425
5 Participants
Reference: blender/blender#93425
As the original bug https://developer.blender.org/T80639 is already closed, creating new bug - but this time detailed analysis is added.
Operating system: Linux (Fedora)
Graphics card: N/A
Broken: 2.90 and master
Worked: without link time optimization (LTO)
makesrna crashes during the build with enabled LTO. See https://bugzilla.redhat.com/show_bug.cgi?id=1874398#c6
Linux distribution like Fedora have enabled LTO by default (https://fedoraproject.org/wiki/LTOByDefault) exposing the failure.
Yes, it does happen with blender 2.90 as well. I believe this is another case when enabled LTO reveals some real bug in the source code.
build output
running under gdb gives:
Added subscriber: @mtasaka
So the backtrace shows that:
Then I tried debugging where failure happened in init_structDNA(). Then:
*r_error_message = "TLEN error in SDNA file";
*r_error_message = "TYPE error in SDNA file";
line is executed. That means that at the line*data == MAKE_ID('T', 'L', 'E', 'N')
if (*data == MAKE_ID('T', 'Y', 'P', 'E'))
, the 'data' pointer didn't point to the expected address.'MAKE_ID('T', 'L', 'E', 'N')'MAKE_ID('T', 'Y', 'P', 'E')
address.cp = pad_up_4(cp);
, before this line is executed, cp points to the expected address (compared to x86_64 results), but after this line is executed, on x86_64 cp is moved to the expected address, but on s390x, the pointer "cp" does not move compared before this line is executed.So: finally, this means that pad_up_4() is not doing what is expected here. Looking at pad_up_4(), this is to round up the given address to 4-byte aligned address - so this means that the given sdna->data is at first expected to be 4-byte aligned. But actually on s390x, it is found that sdna->data is only 2 bytes aligned, but not 4 bytes aligned.
By the way,
So looking at makesdna.c: in main():
DNAstr is only defined as const unsigned char buffer. The alignment requirement for char buffer is only 1 byte on all architecture, so there is no guarantee that DNAstr is put as 4 bytes aligned - this is up to linker or so. On x86_64, it seems that DNAstr is always put on 4 bytes aligned address, but it seems on s390x + LTO (link time optimization), linker + something else seems to put DNAstr on only 2 bytes aligned address - and AFAIK we cannot complain about this.
So the correct way is perhaps force DNAstr to be put on 4 bytes-aligned address - this is toolchain-dependent method.
0001-Fix-#93425-makesdna-force-DNAstr-to-be-4-bytes-align.patch
Suggestion patch
Oops.. actually the executed line was
, corrected.Added subscribers: @ideasman42, @iss
@mtasaka Sorry for late answer, not sure if this is still an issue, but I would suggest to send patch via https://developer.blender.org/differential/diff/create/ (or big submit code addon on main page on this site)
CC @ideasman42
This issue was referenced by
2d429bfdf8
(Again) makesrna crashes during the build with LTO on s390x architecture (Linux) :to (Again) makesdna crashes during the build with LTO on s390x architecture (Linux) :Changed status from 'Needs Triage' to: 'Resolved'
