Impossible to run Modal operator with simultaneously open props dialog (Blender crashes) #93478
Reference: blender/blender#93478
Operating system: Linux-5.15.4-x86_64-AMD_Ryzen_3_PRO_4350G_with_Radeon_Graphics-with-glibc2.33 64 Bits
Graphics card: AMD RENOIR (DRM 3.42.0, 5.15.4, LLVM 13.0.0) AMD 4.6 (Core Profile) Mesa 21.2.6
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash:
84da05a8b8
2.93.6, 2.93.7, 3.0.0 and 3.1.0 all are broken.
Worked: (don't know)
Blender crashes while trying to display operator properties dialog (invoke_props_dialog) and add
the same operator as the modal handler (modal_handler_add(self))
I think it's the same problem as in the (closed) task blender/blender-addons#48196
Try to invoke corresponding operator and then to return {'FINISHED'} or {'CANCELLED'} from the modal() handler.
Then blender crashes after pressing ESC or closing dialog.
Sample code:
I think that impossibility of creating modal operators which can simultaneously have open properties
dialog for on-the-fly corrections lead to endless tries to create custom bgl-rendered UIs which is just
an unneeded overhead.
Please, review the mentioned bug, AFAIK it was already fixed but somehow reappeared upstream...
Added subscriber: @atgote
Added subscriber: @mano-wii
Thanks for the report, I can confirm the crash with the example operator.
But it doesn't seem to be conventional to use
invoke_props_dialog
andmodal_handler_add
in the same operator.The two modal operations are performed at the same time and both can free the operator, causing the one trying to use the operator later to crash.
I don't know what is the point of running an operator along with a popup, maybe it's better to separate the two things (Menu and operator).
Just as an example - choose a "modifier" from Enum field which influences the operator action - and user can check the result before finalizing the operator execution (somewhat like with Undo/Redo dialog)
But the idea behind my search was to use modal handler to improve UX when using the props dialog. That is to have dialog responding to keypresses like add or remove (filter) / UI elements (props).
Something alike searching for an operator with operator search dialog (F3) but a little bit more powerful, allowing not only list-search, but UI-elements 'filter' - different operator/presets buttons for example.
That is - user may enter some keystrokes to filter available actions and then press the operator button or may just find the button in the list and press it without using filtering at all.
Is there workaround for it? In my case I would like for user to be able to pick color, when he uses modal operator, by using context.window_manager.invoke_props_dialog(self) .
Answering my own question:
Why do you actually want to return {'FINISHED'} or {'CANCELLED'} from the modal if I may ask?
I mean I could imagine the crash being prevented by actually closing the dialog as well when the operator is freed from the modal, but I assume this is not what you are after either?
