Renderings vom 2.9 LTS produce different results than 3.0 #93710
8 Participants
Reference: blender/blender#93710
Graphics card: NVIDIA GeForce RTX 3070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.12
Broken: version: 3.0
Worked: 2.93.5, branch: master, commit date: 2021-10-05 12:04, hash:
a791bdabd0
Render looks broken in 3.0 with denoising
Download https://drive.google.com/file/d/10VwtBGw_wD3nBIFMGLUW8qooYDEs8sta/view?usp=sharing
Render it with the settings in that exact same resolution with denoising enablebed. The denoised image hast some strange light shining on the humans in the very front row. the noisy image does not have that. It works as expected in 2.9 LTS
This image shows the artifact. It's the "yellow" arms in the bottom of the image that only shows up after denoising.
Here is a simplified file and set of steps provided by @Alaska
Added subscriber: @DMan
#95814 was marked as duplicate of this issue
Added subscribers: @pmoursnv, @Alaska
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
I am able to reproduce this issue on my setup. However I can't figure out what's wrong because if I enable
Denoising Data
so I can look at it and investigate what's wrong, the issue goes away.Here is an image showing the artifacts (Notice that the people in the bottom portion of the image have yellow "glowing" arms):
CC @pmoursnv as it appears to be limited to the OptiX denoiser.
Operating system: Linux-5.15.0-2-amd64-x86_64-with-glibc2.32 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 495.44
Blender version: 3.1.0 Alpha, branch: master, commit date: 2021-12-04 01:26, hash:
5ef5a9fc24
Added subscriber: @Sergey
I will also CC @Sergey because upon further testing the issue mostly disappears if
Use tiling
is disabled or the tile size is increased to cover the entire image.Note: I also tested with Blender 3.0 and the same thing I've noticed also occur there.
I have simplified the file and got some steps to reproduce it from scratch.
9464 x 4320
(I couldn't reproduce the issue with other render resoltuions)Adaptive Sampling
is on. You can reduce theMax Samples
parameter to something like 64 to speed up renders.OptiX
with the passes set toAlbedo and Normal
Use Tiling
is enabled and the tile size is less than the render resolution.Render Properties
tab and enable ONLY these render passes.Here is a file with steps 1-6 done for you.
#93710 Simplified.blend
The artifact is the horizontal line near the top of this image:
Changed status from 'Needs Developer To Reproduce' to: 'Confirmed'
So the problem here is a traditional case of integer overflow. What is happening is that for denoising, Cycles loads the entire huge image into a GPU buffer. Since
1766549418
this now theoretically works with the OptiX denoiser by splitting up this image buffer into smaller tiles that are denoised separately. But there is a catch: thewidth
,height
androwStrideInBytes
values passed to the denoiser are 32-bit integers and unfortunately there is code to calculate the size of the entire image by multiplyingheight
(or a y coordinate close to that) androwStrideInBytes
. In this case the result is larger than what a 32-bit integer can hold and therefore overflows, causing the denoiser to read/write data at bogus locations, which shows up as artifacts.rowStrideInBytes
is affected by the width of the image and how many render passes are active, hence why the problem goes away if you reduce the width or disable enough render passes (including hidden render passes that one does not select in the GUI, e.g. enabling auto tiling adds a hidden render pass, adaptive sampling adds two hidden render passes). To fix this the calculation will need to be done in 64-bit (by casting to 64-bit before multiplying).Unfortunately this needs fixing in both Cycles and inside the driver, so it's not a quick thing to do ...
Added subscriber: @Raimund58
Added subscriber: @Wovchick
Added subscriber: @Renderbicks
@pmoursnv, Think is better (for the time being, at least) copy an implementation of the tiled denoiser to
optix/device_impl.cpp
so that we don't bump driver version requirement.Additionally to the integer overflow in the
optixUtilDenoiserInvokeTiled
we might have an overflow in the denoiser related kernels. I've tried addressing those, but is only the first tile which is denoised correctly. There is something I am missing and wouldn't mind a second pair of eyes. Attached current state of the patch. It is a bit excessive on int64 usage in theoptixUtilDenoiserInvokeTiled
, in theory should be enough to cast before multiplication, I was just trying to eliminate any doubt of me missing some overflow.optix_int_overflow.patch
I was able to get rid of the artifacts with just this patch and a driver that has the driver-side fixes (they made it into the last r510 release, so need at least Windows 511.79 or Linux 510.54):
But had last tried this a while ago, and had since been waiting for the driver to release, so will need to recheck too.
Have you also tested the latest Studio driver 511.65?
Like I said, you need at least 511.79 on Windows, 511.65 is too old.
This issue was referenced by
8cdee3a6d4
