Geometry Nodes: Spline Length node doesn't evaluate on Sample Curve #93780
Reference: blender/blender#93780
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 497.09
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash:
f1cca30557
Hello,
the Spline Length field doesn't seem to evaluate in this scene. I'm using it on a "Sample Curve" node.
deform along spline - broken.blend
SHORT VERSION:
LONG VERSION:
In this scene I tried to make a deformer along curve.
I'm using a Map Range node as follows: From start to end of the cube, I map it to start to end of the Curve.
The curve has a length of 3.874. If I manually type that in the Map Range's "To Max", then it works.
If I use the Spline Length to get the length procedurally, then it just produces 0.
As a workaround, I can use the Attribute Transfer node to essentially transfer the length on itself, and then it somehow works.
Added subscriber: @OrestisKonstantinidis
Geometry Nodes: Spline Length node doesn't evaluateto Geometry Nodes: Spline Length node doesn't evaluate on Sample CurveAdded subscriber: @mano-wii
I'm not very familiar with this, but it seems weird to use a node called "Spline Length" on an object that doesn't have a spline (is that the length of which spline?).
Was the intention to use the Curve Length node instead?
Thanks for the report. This is because the factor input of the sample curve node is not evaluated on the curve, it's evaluated on the geometry that evaluates the entire field network. In this case that's a mesh, which doesn't have a "spline parameter" like @mano-wii was saying.
I added a task for better warnings in these situations: #94039
