Error while exporting gltf in Blender 3.0 #93929
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
5 Participants
Reference: blender/blender-addons#93929
Version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: f1cca3055776, type: release
Build date: 2021-12-03, 00:44:02 Platform: 'Windows-10-10.0.19043-SP0'
I get this error when trying to export to gltf in Blender 3.
This happen as soon as I change something in the scene and try to export it, this error appears.
A second try exports the file correctly and the error disappears. But it appears again as soons as something will be changed.
How to reproduce:
Repeat step 2
Another try and the error disappears. Objekt will be exported.
Is there a fix for this or can I do something myself?
2021-12-10 12-43-11.mp4
Added subscriber: @ChristophWerner
blender/blender#94678 was marked as duplicate of this issue
blender/blender#93937 was marked as duplicate of this issue
Hi, thanks for the report. Can not reproduce here on master and 3.0.0
Could you please share your export settings? (you can find them in sidebar of the the file view)
Here're my settings. Maybe when preferences are loaded?
And here's a video to see what happen.
Added subscriber: @Zoni
Thanks for clarifying. Can confirm.
Added subscriber: @scurest
While it's easy to fix (invoke should not modify settings while iterating over it; just handle export_selected before the loop), save_settings should also not save export_selected in the first place since it only exists for backwards compatibility.
Added subscriber: @JulienDuroure
Proposed fix: https://github.com/KhronosGroup/glTF-Blender-IO/pull/1497
@JulienDuroure Thank you very much! I've have tested your fix. Seem to work fine so far!
This issue was referenced by
503570ad70
Just out of curiosity: will the fix also be included in the next official update?
Hello,
This will be included in 3.1 alpha with next build (tomorrow)
There is no plan to add it in next 3.0.1 corrective release (This is not a regression, not a critical bug).
Workaround you can use if you want, is writing this in python console:
Thank you. I've updated the py code file already with your changes.
Added subscribers: @labguy, @iss
