Python multiprocessing error - NotADirectoryError #93980
Reference: blender/blender#93980
Operating system: Mac OS Monterey 12.0.1
Graphics card: None
Broken: 3.0.0
Worked: I haven't tried other versions
When scripting with python and using multiprocessing, the Child process crashes with a strange error.
Currently getting an error with multiprocessing, this is the code:
print(title)
print('module name:', name)
if hasattr(os, 'getppid'): # only available on Unix
print('parent process:', os.getppid())
print('process id:', os.getpid())
info('function f')
print('hello', name)
info('main line')
p = Process(target=f, args=('bob',))
p.start()
p.join()
print("done")
main()
This is the output when using Blenders Python:
Expected output (This is what I get when I don't use Blenders Python [Python 3.9.0]):
It seems like the child that gets created from multiprocessing just crashes. Anyone have any ideas?
Added subscriber: @struny
Added subscriber: @chemicalcrux
The problem is that it's trying to run a script with the name of the Text object in blender. So, if the Text object is called "Text", it tries to run a script called "Text" (which does not exist).
In my case, I'm running a copy of Blender I built, and it appears to be trying to find the script in the
D:/
directory.FileNotFoundError: [Errno 2] No such file or directory: 'D:\\Text'
If I save the text file as "test.py", then rename the Text object to "test.py", the script works correctly...but that's pretty much just a coincidence.
@chemicalcrux
For me it seems like by default it is looking in my
.blend
file (NotADirectoryError: [Errno 20] Not a directory: '~/Documents/Blender/webcam.blend/test.py'
) to find the python script, and I am not sure why. I already have my text block namedtest.py
.I was able to find a work around:
If you modify the
__file__
variable and point it directly to where the python script is located, it seems to work.file = '../../~/Documents/Blender/testing/test.py'
Added subscriber: @lichtwerk
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Not getting this error on Linux (tried 3.0 and master).
Looks like this has been discussed before [on Windows at that time] https://blender.stackexchange.com/questions/8530/how-to-get-python-multiprocessing-module-working-on-windows
So the
__file__
trick is probably the recommended workaround, will doubt this is considered a bug, will let #python_api decide though.Added subscriber: @Jindrich-Cech
This bug is persistent up to Blender 3.2.0 (Alpha). MacOS Blender Text editor provides bad script file path to modules (in my case /Users/jindra/Projects/Blender/gps.blend/gps.py instead of /Users/jindra/Documents/gps.py). If I run the same commands in Blender Python console - works OK. Everything is clear from added pictures...
