the knife tool does not work #94055
Closed
opened 2021-12-14 12:00:54 +01:00 by stefano · 12 comments
Graphics card: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.76
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: f1cca30557
when i project lines on a plane i get an error message
I draw two planes. I divide the first into squares (ctrl + r), I delete only the faces, I project it on a second plane. error
p.s.
on blender 2.93 it works perfectly
**System Information** Operating system: Windows-10-10.0.19043-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 3080 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 496.76 **Blender Version** Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: `f1cca30557` Worked: (newest version of Blender that worked as expected) when i project lines on a plane i get an error message I draw two planes. I divide the first into squares (ctrl + r), I delete only the faces, I project it on a second plane. error p.s. on blender 2.93 it works perfectly ![Screenshot_1.jpg](https://archive.blender.org/developer/F12739160/Screenshot_1.jpg)
Author
Added subscriber: @stefanocioncoloni
Added subscriber: @randum
Do you use knife project tool? If yes then it seems you didn't select cutting object properly.
From the documentation:
To use Knife Project, first in Object Mode select the object to be cut, then in Edit Mode, select the cutting object (Ctrl-LMB), and choose Mesh ‣ Knife Project.
At list it looks that the message is about it.
I tried this and this only works if mesh to be cut has faces. Don't know how it used to work in versions before 3.0
Do you use `knife project` tool? If yes then it seems you didn't select cutting object properly. From the documentation: > To use Knife Project, first in Object Mode select the object to be cut, then in Edit Mode, select the cutting object (Ctrl-LMB), and choose Mesh ‣ Knife Project. At list it looks that the message is about it. I tried this and this only works if mesh to be cut has faces. Don't know how it used to work in versions before 3.0
Added subscriber: @deadpin
Indeed it sounds like the change in Knife project workflow is the cause here. Furthermore, I can correctly Knife project that grid (with only edges) onto a plane correctly. Let us know if you are still running into this issue -- provide a simple .blend file showing your problem exactly if necessary.
Author
This comment was removed by @stefanocioncoloni
*This comment was removed by @stefanocioncoloni*
Author
i used the same file with 3.0 and 2.93. Version 3.0 does not allow the knife, the old one does{F12761050}
i used the same file with 3.0 and 2.93. Version 3.0 does not allow the knife, the old one does{[F12761050](https://archive.blender.org/developer/F12761050/TMP.blend)}
Again, this is a change in workflow from previous versions -- do not enter edit mode with both planes selected, only enter edit mode with the plane you want to cut. Try the following:
  • Select only the "Plane" object
  • Enter edit mode
  • Select "Plane.001" from the Outliner (or with Ctrl+Click in the viewport)
  • Knife Project
Again, this is a change in workflow from previous versions -- do not enter edit mode with both planes selected, only enter edit mode with the plane you want to cut. Try the following: - Select only the "Plane" object - Enter edit mode - Select "Plane.001" from the Outliner (or with Ctrl+Click in the viewport) - Knife Project
Author
I misunderstood your explanation, thank you very much
It sounds like your issue is resolved then? I'll close this task for now.
Reference: blender/blender#94055
