Cycles Manifold Next Event Estimation #94120
8 Participants
Reference: blender/blender#94120
Short term:
shade_surface
kernel somehow, running before or after?shade_surface
kernel?Longer term:
Added subscriber: @brecht
Added subscriber: @olivier.fx
Added subscriber: @Raimund58
Added subscriber: @S1ft
Added subscriber: @Alaska
A bit of consolidation, adding references to:
#96990: MNEE caustics with Multiscatter GGX materials are inconsistent.
#96991: MNEE does not fall back to alternative caustic technique when MNEE does not work.
#96992: MNEE caustics are treated as "direct light" when they should be "indirect light".
#97056: MNEE caustics don't render with specific materials when Filter Glossy = 0
#97054: Caustics Shadows Artifacts
Added subscriber: @quantimoney
Was testing the shadow caustics. Noticed that for some reason, the viewport render is able to show me the caustics perfectly, but actually rendering an image out disregards any form of special caustics. Any idea why this is happening? The surprising thing is for certain cases the caustics gets rendered into output correctly, but in other cases, only parts have the caustics in scene.
This might be just a case of complexity in the scene thats causing the issue, but irrespective of that, if its able to show me a clear image in the viewport (after waiting for the samples to run), then it should show me the same when rendering output. Adding this comment here, can create task later if its general issue, and not something wrong with personal file.
(private work, cannot send actual file here, therefore attaching screenshots)
viewport realtime view (this has a sky texture for lighting, using just a sun lamp also gives this issue, but localised area lighting sometimes works, sometimes does half of those shadow rays seen in image)
render output
Added subscriber: @makizar
Thanks for reporting this @quantimoney, I can't really explain why you would see a difference between viewport and render, could you maybe post a simple scene showing this behavior (one of the windows for example)? Do you have render only modifiers that could alter the mesh in any way? Thanks!
This issue was referenced by
58be9708bf
