Curve data structures relation design #94193
16 Participants
Reference: blender/blender#94193
We currently have multiple curve data types. The new ones:
CurveEval
: #87245 (Geometry Nodes: Curve Support Implementation)Editable with geometry nodes Supports different types of curves
Data structure simpler to edit (like editmesh) Not a datablock
C++ data structure that cannot be saved to file Not in Python API
** No rendering support
Hair
: #68981 (New curves object type)Not editable with geometry nodes Always Catmull-Rom curve
Data structure more memory efficient Is a datablock
DNA C data structure that can be saved to file In the Python API for exporters/renderers
** Renderable with Cycles and Eevee
And then the older ones:
Curve
Supports both curves and surfaces with multiple types, as well as text Datablock
Can be saved to file Not renderable directly, but converted to mesh
EditNurb
Supports both curves and surfaces with multiple types Runtime data structure created from
Curve
, likeEditMesh
** Supports curve/surface edit mode
ParticleSystem
hairPart of modifier on
Object
datablock Can be saved to fileEdited in particle edit mode Renderable with Cycles and Eevee
With the addition of D11592: Alembic/USD: use geometry sets to import data, it raises the question how for Alembic curves should be imported, since usually that is hair you want to render. Alembic (and many other applications and file formats) do not make a distinction here, so choosing one or the other is not ideal. And of course in terms of functionality users would want to be able to do everything with the same datablock.
I'd like to get this design decided on so we are clear on the way forward, even if not everything might be implemented immediately. Some potential options:
CurveEval
as anEditMesh
-like runtime representation that can convert to/fromHair
, which is what remains used for rendering and the Python API.CurveEval
and useHair
(renamed to something more general) instead.Changed status from 'Needs Triage' to: 'Confirmed'
Added subscriber: @brecht
Added subscribers: @HooglyBoogly, @kevindietrich, @JacquesLucke
@kevindietrich, @HooglyBoogly, @JacquesLucke, I would like to get your opinion on this, since it affects the design of D11592 which would be nice to have in 3.1.
Personally I would think of option (1) or even (2) if possible. From experience the mesh/editmesh distinction does lead to performance issues and code complexity, and curves don't need complex topological operations like meshes. But I feel like perhaps I'm missing the bigger picture of where you want to go with
CurveEval
.When building
CurveEval
I saw it as corresponding to Blender's existing curves (Curve
/Nurb
) and eventually replacing their implementation.I've wondered before if going further towards the design of the hair data structure might have been preferable. While
CurveEval
gives some contiguous chunks of memory to work on (better thanNurb
), it wouldn't be nearly as efficient asHair
for the many small splines case.I always thought that the two could compliment each other.
CurveEval
for doing more "CAD-like" tasks that require more precision,Hair
when the number of splines is important, and for more organic situations. Edit mode operations would also be quite different.While one could probably be made to do the tasks of the other, that wouldn't necessarily be most efficient or intuitive for the user. It's similar to the mesh vs. point cloud distinction. They're separated for clarity and efficiency, not necessarily because mesh couldn't do the same thing.
I'd like to add
CurveEval
to the python API. I had two main questions:Nurb
to emulate the old one?Rendering
I'd think both could be rendered, maybe even using the same implementation. For me the question is what happens to curves in existing files that didn't have a "bevel/curve to mesh node" before? Would we accept changing what those files looked like?
Datablock
Since
CurveEval
can be embedded intoCurve
(and already is for rendering), this one doesn't seem like a big deal to me.Geometry Nodes
Obviously
CurveEval
is already supported in quite a few nodes. Some of those node operations could also supportHair
, or we could add a separate node that processes hair (I think I prefer the latter).As far as I know there are still open questions about how hair should be generated/rooted. It seemed to me like a node with
Points
,Normal
, andLength
inputs would be a good start.Ah, I typed that comment before I saw your edit and comment, so I didn't see that you were proposing to remove
CurveEval
. I still think the distinction is important, similar to meshes vs. point clouds like I mentioned above. I could write more, but I'll see what you think about what I wrote already. I'll just add a comment about the point you added.Saving in Files
I didn't make a real design for saving
CurveEval
in files yet (since it's just a runtime data structure at the moment). But I thought about having a DNA struct that would just be storage for saving and loading it, basically just a pointer to a few arrays and custom data.Hair and CurveEval relation designto Curve data structures relation designFor simplicity and "proceduralism", I would go for option 2, and just have a single data block for anything curve-like. We can have object level attributes to tell how control points should be interpreted and interpolated. I don't see the reason to have specific data structures for every case (
BezTriple
, etc.). This is how some other software packages handle it, and similarly for I/O formats like Alembic and USD.Another of my concerns is arbitrary attributes, besides D11592: Alembic/USD: use geometry sets to import data, there is also D11591: Alembic: import arbitrary attributes which works for meshes and point clouds, but not curves (I do have files from users to help develop this feature), as I am basing it on the attribute API which uses an ID block. The old datablocks do not really support attributes, and
CurveEval
is awkward to work with here, and would introduce a lot of code complexity.Option 1 makes sense if we need a data structure that is more fitted for manual edits (like
BMesh
in edit mode).There is a fundamental difference between meshes and point clouds. Having them separated makes sense.
Curve
(et al.) vsCurveEval
is more comparable toMesh
vsBMesh
, IMO.Curve
also includes NURBS surfaces and Text that are definitely distinct fromHair
, and probably should never have been part of the same data structure in the first place. So assuming we are not considering those as part of this.Beyond that there are still distinct features between hair and other curves that matter on a user level, even if it would all just be attributes. Hair has an (optional) attachment to surfaces (probably polygon index + barycentric uv). Other curves have tilt, cyclic and poly spline types, which at least most renderers generally can't render directly.
I think it makes sense to have some level of distinction on a user level, but more only on the level of a "curve type" or "render as" setting on a shared datablock. There are definite trade-offs, but it's what currently seems better to me.
If it's a shared datablock you get reduced code complexity, better interop with other apps and file formats, and nodes/operators working on both that otherwise probably only would have been implemented for one. A downside is that the UI can be confusing in that some nodes, operators or settings may be exposed but don't work for unclear reasons. This can be clarified somewhat but not hidden completely from the user.
I also imagine that you would have separate edit mode and groom mode, much like we have a separate edit and sculpt modes for meshes. One for more precise CAD like operations, the other for editing lots of curves at once with brushes.
Under this assumption, you would of course end up with a different data structure. There could still be an equivalent to
EditMesh
inCurveEval
. However I think it is important that you can e.g. load an Alembic file, modify the positions and render that without converting to such a data structure.If we do make a change like this it can of course it is a significant project. For example we don't have an edit mode for
Hair
currently, and so you can't just move over curves to that without loosing functionality. Steps would probably look something like this:Hair
in Alembic/USD importers (for 3.1)Hair
toCurveEval
, or rewrite geometry nodes to useHair
and addCurve
toHair
conversion (whenever the new hair project starts)Hair
(whenever the new hair project starts)Curve
toNURBS
and move individual curves over toHair
, perhaps renamed toCurves
(much later)Added subscriber: @Garek
Hans and I discussed the topic a bit today. We have some notes here: https://hackmd.io/@II9-Bkl4TJifCqGL2jgbUw/BJmWeEs9Y
We can continue talking about it next week.
Added subscriber: @GeorgiaPacific
Added subscriber: @nantille
In reply to the question in your notes @JacquesLucke : "Under what circumstances can render engines benefit from rendering curves directly instead of a mesh generated from a curve?".
Easily any work related to using lots of splines like in my case in neuroscience. When rendering billions of custom splines, this is where you want to avoid meshes. But there are other cases than this of course.
I've submitted code for making curves renderable as hair in Cycles several years ago (https://developer.blender.org/D3822). I've even kept up to date my code that supports the latest master branch (and Hair object) in Cycles. Feel free to ping me, should you want to test it.
Ideally, the new Hair object would allow users to generate any number of splines with any number of points (+ radius + optional custom data thanks to new data attribute) and to set their positions/orientation manually or by code, not necessarily attached to a mesh surface. A great addition would be to be able to anchor one spline to another.
Also, the data would not be copied from Blender to Cycles. Instead Cycles would directly use the objects that Blender has in memory, otherwise we're looking at huge amounts of wasted memory.
Added subscriber: @lichtwerk
Added subscriber: @ChengduLittleA
A few comments on the doc:
The curve trimming support thing I'm researching on is here: https://devtalk.blender.org/t/better-curve-surface-support/21113/44
The main thing I'm concerned here is that I need to use a curve in uv space to do the trim. I thought I should just keep you guys posted on this 🤔 .
It seems fine to default to the type that's fastest for rendering. However, Poly and Bezier splines have important use cases in many workflows (like converting from mesh edges to splines).
What we did for
CurveEval
was just add right and left handle positions and types as attributes on the control points. The handles aren't control points then, they're just attributes that are used to find the evaluated shape for Bezier splines. That approach has worked quite well I think.Great! I also think we should move part of the data structure to a separate DNA struct so it can be embedded in grease pencil data.
In Blender it is already supported, so we have to support it if we actually want to replace the implementation of the current curve object.
I don't think these tasks are that related actually, since this is really about curves rather than surfaces. Though I think the general purpose
Curve
data-block should be replaced with a more specific type for surfaces.For @kevindietrich to continue work on better hair import from Alembic / USD, I suggest the following:
Hair
data structure, so that it can be rendered by Cycles & Eevee.Does that seem reasonable?
Is this about run-time data only? Can we disable storing
Hair
objects in files for now? That would make the refactoring much easier, also because Hair objects can remain experimental and hidden from the user.It feels like the id data block renaming should happen before we expose it to users.
It is mainly about runtime only data, but since you can apply modifiers this could actually get saved in .blend files.
We could leave them out of applying modifiers or even file saving. But if we could rename the data structure and make any other required changes first that would be better I think, since it's quite confusing to have such limitations.
For the datablock name, we could use
Curves
to be consistent with USD / Alembic, though it is confusing with the existingCurve
datablock name. TheHairMapping
stuff could be removed until we decide on a convention for that.Jacques and I discussed the naming on the #core module channel for a while. In general we agreed that using a name with a plural like "curves" doesn't work because you might have multiple "curves" objects, and the double plural sounds quite weird. We also thought about common variable names. Here are the final changes proposed:
Hair
->SplineGroup
(withspline_group
variable name) (DNA and RNA)Splines
type for embedding in an ID data-block (for future grease pencil support) (withsplines
variable name) (only DNA)HairCurve
->SplineSlice
(DNA and RNA)HairMapping
structOB_HAIR
->OB_SPLINE
BKE_hair.h
->BKE_spline.h
(BKE_spline_group.h
would be another option)BKE_spline.hh
->BKE_curve_eval.hh
(in order to be different from the previous name)DNA_hair_types.h
->DNA_spline_types.h
hair.cc
->spline.cc
(spline_group.cc
would be another option)See P2700 for the proposed
DNA_spline_types.h
file.Another option would be to embed the
Splines
data structure in the existingCurve
data block. That might make naming simpler. Personally I think that makes any transition in the UI and the code much less clear though.I would really argue for following existing naming standards and conventions. I don't know which other software calls equivalent data structures "spline group" or something involving "spline", but at least that's not what is used in USD/Alembic/Houdini/Maya. To me the term "spline" also sounds more like a technical term than one for users.
I agree multiple "Curves" objects is a bit odd, but it's also the most common name for this. I think it can work anyway, but if it's really considered a problem I would still prefer something like "CurveGroup", "CurveGeometry", "CurveSet".
Even if we go for
Curves
and ignore the annoyances it causes when naming variables, it's still not clear to me how we present the difference between the two curve object types in the ui. If we allow having non-experimental Curves objects in .blend files, then we have to teach users that there are now two different kinds of curve objects, and what their difference is, and when to use which one, and what the limitations of each are. That definitely has to be approved by ui team people and probably Ton. I'm also not sure if adding a new data-block/object type in bcon2 is ok.All of that would be quite a bit easier of the new data block would stay run-time only data in 3.1. That would give us time to decide how to present the two different curve object types in the ui.
We can move the whole thing to 3.2 regardless since this is getting complicated.
Thinking about it more, it's probably good regardless to keep this a runtime only data structure until there is some type of editing tool for this, or at least geometry nodes. Otherwise it's not particularly useful, and confusing that the curves are not editable. It's not so different from particular hair which you also can't apply with a modifier to become its own object.
For the UI, perhaps in a transition period this could be called "Hair Curves" or something along those lines, until it can actually existing general purpose curves. In other places like datablock filters we could avoid making a distinction and group them together under a single name.
Added subscriber: @hlorus
Added subscriber: @RedMser
Added subscriber: @AndyCuccaro
Added subscriber: @DuarteRamos
This issue was referenced by
fcec55796e
Added subscriber: @Osares
Added subscriber: @hzuika
