Blender Crashing While Appending Animation Action #94264
Closed
opened 2021-12-20 03:13:18 +01:00 by DenDen · 18 comments
Operating system: Windows-10-10.0.19042-SP0 64 Bits
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.47
Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: f1cca30557
Appending animation actions while in pose mode crashes Blender.
(Crash appears only when action is removed from the scene/outliner but still present as an asset.)
  • Open #94264.blend file
  • {nav File > Append > AnimActions.blend >Action > (double-click on any)}
Test File:
#94264.blend
AnimActions.blend
**System Information** Operating system: Windows-10-10.0.19042-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 472.47 **Blender Version** Broken: version: 3.0.0, branch: master, commit date: 2021-12-02 18:35, hash: f1cca30557 Worked: (newest version of Blender that worked as expected) **Short description of error** Appending animation actions while in pose mode crashes Blender. (Crash appears only when action is removed from the scene/outliner but still present as an asset.) **Exact steps for others to reproduce the error** - Open `#94264.blend` file - {nav File > Append > AnimActions.blend >Action > (double-click on any)} Test File: [#94264.blend](https://archive.blender.org/developer/F12769126/T94264.blend) [AnimActions.blend](https://archive.blender.org/developer/F12768684/AnimActions.blend)
Author
Added subscriber: @Densle
Member
Member
Hi, thanks for reporting. Can not reproduce crash on current master and 3.0.0
Does this happen on appending data from specific file?
Can you reproduce the crash with factory prefs: {nav Edit > Preferences > Save & Load (3 horizontal lines) > Load Factory preferences}
I tried to append from this file: Character.blend
Hi, thanks for reporting. Can not reproduce crash on current master and 3.0.0 Does this happen on appending data from specific file? Can you reproduce the crash with factory prefs: {nav Edit > Preferences > Save & Load (3 horizontal lines) > Load Factory preferences} ![image.png](https://archive.blender.org/developer/F12717357/image.png) --- I tried to append from this file: [Character.blend](https://archive.blender.org/developer/F12765672/Character.blend)
Member
Author
That's valid.
With preferences reset, it still occurs. But I narrowed it down a bit.
It looks like it's got something to do specifically with the actions themselves. Because in some files, it loads in fine whiles others, it doesn't.
I attached some blend files if you want to give them a whirl.
AnimActions.blend ChrRig.blend
Here is also a crash log if it help.
004-0060_Animation_v0010.crash.txt
That's valid. With preferences reset, it still occurs. But I narrowed it down a bit. It looks like it's got something to do specifically with the actions themselves. Because in some files, it loads in fine whiles others, it doesn't. I attached some blend files if you want to give them a whirl. [AnimActions.blend](https://archive.blender.org/developer/F12768684/AnimActions.blend) [ChrRig.blend](https://archive.blender.org/developer/F12768685/ChrRig.blend) Here is also a crash log if it help. [004-0060_Animation_v0010.crash.txt](https://archive.blender.org/developer/F12768690/004-0060_Animation_v0010.crash.txt)
Member
Hi, thanks for the file. Appending action from AnimActions.blend results to crash.
Also, looks like crash only appears when action to be appended is marked as asset
Will make sure if similar report already exists or not.
Hi, thanks for the file. Appending action from `AnimActions.blend` results to crash. Also, looks like crash only appears when action to be appended is marked as asset Will make sure if similar report already exists or not.
Member
Added subscriber: @mont29
Cannot reproduce with current master, is it still an issue? Am on linux though, @PratikPB2123 are you on windows or other OS?
Also, if this is specific to assets, think this is more for #asset_browser / #pipeline_assets_i_o projects than core.
Cannot reproduce with current master, is it still an issue? Am on linux though, @PratikPB2123 are you on windows or other OS? Also, if this is specific to assets, think this is more for #asset_browser / #pipeline_assets_i_o projects than core.
Member
Yes, on Windows. I can only reproduce on daily builds. Also tested on lite build but it did not break anything for me.
Operating system : Windows-10-10.0.18362-SP0 64 Bits
Graphics card : AMD Radeon(TM) 535 ATI Technologies .```
Yes, on Windows. I can only reproduce on daily builds. Also tested on lite build but it did not break anything for me. --- ```System Information Operating system : Windows-10-10.0.18362-SP0 64 Bits Graphics card : AMD Radeon(TM) 535 ATI Technologies .```
I do not understand what this means... Can you be more specific here? I have the feeling I am missing something in the steps to reproduce the issue...
> (Crash appears only when action is removed from the scene/outliner but still present as an asset.) I do not understand what this means... Can you be more specific here? I have the feeling I am missing something in the steps to reproduce the issue...
Member
For example, refer AnimActions.blend.
In that file, Action is marked as asset but not present in outliner.
When we append that action in another file (say #94264.blend), it simply crashes.
Also, if you want to reproduce from scratch:
  • Open default scene
  • Add Armature {nav Shift A > Armature}
  • Switch to pose mode
  • Append action from AnimActions.blend
(Let me know if anything is not clear.)
For example, refer `AnimActions.blend`. In that file, Action is marked as asset but not present in outliner. When we append that action in another file (say `#94264.blend`), it simply crashes. --- > I have the feeling I am missing something in the steps to reproduce the issue Also, if you want to reproduce from scratch: - Open default scene - Add Armature {nav Shift A > Armature} - Switch to pose mode - Append action from `AnimActions.blend` (Let me know if anything is not clear.)
Added subscriber: @dr.sybren
OK thanks, then definitely cannot reproduce on linux... Would assume some kind of windows-only issue, maybe @dr.sybren would know more (iirc he was working on some utf-8/path related issues on this OS this week)?
Sybren A. Stüvel self-assigned this 2021-12-21 13:22:29 +01:00
I can reproduce this on Linux.
Update: You have to double-click on the Action in the file browser to get the crash. The "Append" button works fine.
I can reproduce this on Linux. Update: You have to double-click on the Action in the file browser to get the crash. The "Append" button works fine.
This issue was referenced by blender/blender-addons@5876b7836d
This issue was referenced by blender/blender-addons@5876b7836db45d242a55898092e69b3c17b055a9
This issue was referenced by blender/blender-addons@c08568cc37
This issue was referenced by blender/blender-addons@c08568cc376d2e4298710c4172fb0c74f0611de1
5 Participants
Reference: blender/blender#94264
